MAC 1700 Manual
ronaldcox
PostPosted: Thu Mar 23, 2017 5:15 pm    Post subject: MAC 1700 Manual Reply with quote
Hi, Matt,
If you're in a hurry, this might be helpful. https://www.eflightmanuals.com/ITEM_EFM/SITEM_EFM.asp?cID=4443
I have one of those and may have the manual you need.  What I have is the Pilot's Operating Manual for the Control/Display Unit, and Flight Manual Supplements.
I know it is indeed a slide-out replacement for the King KX-170/175 radios.  (It actually IS a KX-170 or 175 radio with a new control front grafted onto it.)
So the KX-170/175 pinouts should be good.
Sorry, I don't have the installation manual, but again, the King info should do it for you.
Ron Cox
Glasair Super II F/T
Almost there..
Ron Cox
Under Construction at C77 - Still just about to fly!
PostPosted: Fri Mar 24, 2017 4:31 am    Post subject: MAC 1700 Manual Reply with quote
At 08:10 PM 3/23/2017, you wrote:
Hi, Matt,Â
If you're in a hurry, this might be helpful.Â
I know it is indeed a slide-out replacement for the King KX-170/175 radios. Â (It actually IS a KX-170 or 175 radio with a new control front grafted onto it.) Â
The KX170B/175B IM is available here http://tinyurl.com/m7xeo39
