trigo(at)mail.telepac.pt Guest
Posted: Thu Mar 30, 2017 6:40 am Post subject: Garmin GPS antenna |
The G3X Installation Manual says, in a "Note" on page 20-1, that "GA35, GA36 and GA37 antennas cannot be used with GDU 37X/4XX units".
Does anybody know why?
(I'm asking because I bought the pretty expensive GA35, as an excellent GPS antenna, before reading this "Note")
Carlos
Enviado do meu iPhone
Bob Turner
Joined: 03 Jan 2009 Posts: 881 Location: Castro Valley, CA
Posted: Fri Mar 31, 2017 11:40 am Post subject: Re: Garmin GPS antenna |
Not sure if this is the sole reason, but in the specs I see a slight mis-match in the dc power needed by the antenna, and what's furnished by the GDU37:
GA 35 needs: 4.0 to 5.0 volts at 60 ma
GDU37 furnishes 4.5 to 5.5 volts at up to 50 ma.
_________________ Bob Turner
RV-10 QB |
Posted: Sat Apr 01, 2017 3:26 am Post subject: Garmin GPS antenna |
Thank you Bob
Could that be for so tiny differences?
Does that makes sense to the electronic experts in this list?
Carlos
No dia 31/03/2017, às 20:40, Bob Turner <bobturner(at)alum.rpi.edu> escreveu:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=467882#467882
Lenny Iszak
Posted: Sat Apr 01, 2017 4:32 am Post subject: Re: Garmin GPS antenna |
I don't think the problem is with the voltage or the current draw. They can't be cutting it that close. It most likely has to do with using a WAAS antenna on a non-WAAS receiver.
You're better off using one of their recommended antennas. Probably way cheaper too.
Lenny
trigo(at)mail.telepac.pt wrote: | Thank you Bob
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Bob Turner
Posted: Sat Apr 01, 2017 9:28 am Post subject: Re: Garmin GPS antenna |
Lenny Iszak wrote: | I don't think the problem is with the voltage or the current draw. They can't be cutting it that close.
If the antenna really needs 60 ma and the box's max really is 50, it could be that simple. Remember many of these antennas were not designed to match a Garmin box - they are off the shelf OEM designs with a Garmin label slapped on.
RV-10 QB |
