KIS TR-1 Nose Wheel Pant
bakerocb
PostPosted: Tue Apr 04, 2017 10:40 am    Post subject: KIS TR-1 Nose Wheel Pant Reply with quote
4/4/2017
Hello Steve, Here are some of the pictures that I have been promising you:
0132: This is a photo of both the nose gear leg fairing (on the left) and
the wheel pant (on the right). The leg fairing was made from a Glastar /
Sportsman nose gear leg fairing. It was assembled from two pieces (a left
and a right). The top was cut off and the bottom modified to fit the opening
in the nose wheel pant. The nose wheel pant came from Van's.
0133: Just another view of the same two items in 0132 described above.
0134: This view shows how the trailing edge of the leg fairing is held
together with hinge material and a hinge pin.
Any questions?
OC
PS: I will send you a separate email with pics of the main landing gear
wheel pants.
Sent: Sunday, April 02, 2017 3:26 PM
To: kis-list(at)matronics.com
Subject: Re: Wheel pants?
Thank you! I'm going to pursue getting them on!
To our success, Stephen McIntosh
 Filesize:  714.15 KB
 Viewed:  4169 Time(s)
 Filesize:  705.12 KB
 Filesize:  690.48 KB
