Torque tube bushing
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
Pocono John
PostPosted: Tue Apr 04, 2017 5:02 pm    Post subject: Torque tube bushing Reply with quote
I had been thinking the 7/8" torque tube (.035) would fit snuggly in a 1" bushing (.058) and that bushing would be welded to a bracket assembly which is secured to the floor.
The plans, however, on the upper left area of sheet 4 show a collar is brazed to the torque tube.
Is the torque tube supposed to rotate in a bushing/collar; or is the torque tube brazed to the bushing/collar and that part rotates in the bracket?
Thank you,
John C
(I did search the forum and looked at numerous photos, but nothing helps).
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Bill Church
PostPosted: Wed Apr 05, 2017 12:27 pm    Post subject: Re: Torque tube bushing Reply with quote
John,
The 1" diameter tube that fits over the 7/8" diameter torque tube is actually three pieces - slices of tube; 2 pieces approximately 5/16" long, and one piece 1" long. One of the narrow (5/16") pieces is slipped onto the torque tube, and brazed to it. This piece acts as a stop, to prevent the torque tube assembly from moving forward. The 1" long piece is brazed to a 13ga flat strip that will get anchored to the floor. And the third piece (5/16" long) is slipped onto the torque tube, with the other 2 pieces in place, and riveted to the torque tube, to act as a retainer.
(see marked-up drawing detail)
Bill C.
 Filesize:  353.33 KB
 Viewed:  1042 Time(s)
Pocono John
PostPosted: Wed Apr 05, 2017 12:50 pm    Post subject: Re: Torque tube bushing Reply with quote
Wow Bill, thanks for the explanation and the graphic. That sure helps!
John C
John Cronin
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
