Ed Godfrey
Posted: Mon Apr 10, 2017 8:31 am Post subject: Circuit protection for backup alternator |
Bob,
I am building an RV10 and installing a B&C 410H backup alternator. I
have installed an ANL circuit protection next to the battery behind the
baggage compartment, to protect the #6 wire that I have going forward,
along the lines of your Z-13/8 schematic. But I was concerned about the
output of the alternator going aft. I have a contactor on the firewall
for the output of the alternator and I was considering installing a
fusible link between the alternator and the contactor for protection.
Are there any issues that you might see with a setup like this? Thanks.
Ed Godfrey
Posted: Mon Apr 10, 2017 8:40 am Post subject: Circuit protection for backup alternator |
At 11:29 AM 4/10/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: Ed Godfrey <egodfrey(at)ameritech.net>
Bob,
I am building an RV10 and installing a B&C 410H backup alternator. I have installed an ANL circuit protection next to the battery behind the baggage compartment, to protect the #6 wire that I have going forward, along the lines of your Z-13/8 schematic. But I was concerned about the output of the alternator going aft. I have a contactor on the firewall for the output of the alternator and I was considering installing a fusible link between the alternator and the contactor for protection. Are there any issues that you might see with a setup like this? Thanks. |
No . . . the alternator is incapable of delivering
current needed to put the b-lead at risk.
Kellym
Joined: 10 Jan 2006 Posts: 1700 Location: Sun Lakes AZ
Posted: Mon Apr 10, 2017 12:31 pm Post subject: Circuit protection for backup alternator |
IMHO you are getting things backwards. You do not need protection for
the heavy wire from the battery to the firewall/starter solenoid.
However, that cable should be #4 minimum, and better #2.
Use the ANL to protect the B lead from the alternator to the main bus,
with the ammeter shunt either right above or below it on the firewall.
Your #6 (or # is appropriate for that B lead.
Kelly
RV-10 40866, flying
On 4/10/2017 9:29 AM, Ed Godfrey wrote:
Bob,
Ed Godfrey
KCHD |
Posted: Mon Apr 10, 2017 1:06 pm Post subject: Circuit protection for backup alternator |
Quote: | Quote: | I have a contactor on the firewall for the output of the alternator and I was considering installing a fusible link between the alternator and the contactor for protection. Are there any issues that you might see with a setup like this? Thanks. |
You probably don't need that long #6 feeder . . .
you can feed the alternator's output into
the system at the starter contactor on the
firewall. A miniANL on a fuseblock or a
MAXI-blade in an in-line fuse holder could
be pressed into protection of this circuit
and eliminate the long wire run.
Ed Godfrey
Posted: Mon Apr 10, 2017 2:43 pm Post subject: Circuit protection for backup alternator |
Bob,
Following the Z-13/8, I am connecting up the backup alternator to the hot side of the battery contactor. With the distance that the power is traveling, I calculated that the #6 wire would be the best choice. Did I choose wrong?
Ed
On 4/10/2017 4:04 PM, Robert L. Nuckolls, III wrote:
Quote: | Quote: | Quote: | I have a contactor on the firewall for the output of the alternator and I was considering installing a fusible link between the alternator and the contactor for protection. Are there any issues that you might see with a setup like this? Thanks. | |
Bob . . . |
Posted: Mon Apr 10, 2017 2:55 pm Post subject: Circuit protection for backup alternator |
 I have been flying my RV-10 with a 2 battery/2 alternator/2 bus Z-14 for 5+ years. Just for reference purposes my configuration includes:
- Both batteries and battery contactors are installed behind baggage compartment
- 2 AWG wire used to to all contactors including a run forward of the firewall for the starter contactor and the main alternator
- 8 AWG wire used for runs to 2 fuse blocks on cockpit sidewalls and for run from SD20 alternator and it's battery contactor in the rear
- ANL current limiters installed on firewall close to alternators for both B leads
- (there is no protection on runs from battery contactors in rear to fuse blocks and starter in the front)
I wouldn't do it any differently if I did it again.
On 4/10/2017 12:29 PM, Ed Godfrey wrote:
Quote: | --> AeroElectric-List message posted by: Ed Godfrey <egodfrey(at)ameritech.net> (egodfrey(at)ameritech.net)
Bob,
Ed Godfrey
Virus-free. www.avast.com
Kellym
Posted: Mon Apr 10, 2017 4:20 pm Post subject: Circuit protection for backup alternator |
Normally, I would agree. However, the RV-10 requires the main battery
behind the baggage compartment for W&B, so it does require one long
heavy lead from the battery to the firewall. IMHO it should be no less
than #4, and really should be #2 for good starter performance, given the
over 10 ft run from battery to starter. Ground is handled through the
aluminum airframe for the battery. Very conventional with master relay
at the battery and starter relay on firewall near where the battery
heavy lead comes through. Vans publishes a basic wiring diagram that is
very conventional for a VFR aircraft, that gives a good starting point
for wire sizes and physical locations. It is easy to modify to meet
goals for endurance bus, redundancy, etc.
On 4/10/2017 2:04 PM, Robert L. Nuckolls, III wrote:
Quote: | >> I have a contactor on the firewall for the output of the alternator
KCHD |
Posted: Mon Apr 10, 2017 4:29 pm Post subject: Circuit protection for backup alternator |
At 05:39 PM 4/10/2017, you wrote:
Quote: | Bob,
Following the Z-13/8, I am connecting up the backup alternator to the hot side of the battery contactor. With the distance that the power is traveling, I calculated that the #6 wire would be the best choice. Did I choose wrong? |
How about Z12 instead? Tie both alternators to
the bus structure at the hot side of the starter
contactor.
Just use the smaller alternator like a stand-by
device like hundreds of TC aircraft. Which
regulator are you using on the small alternator?
Z-13/8 was crafted specifically for minimizing loads
on the diminutive SD-8 alternator with bypassing
the battery contactor. The extra snort
available from the larger wound field makes this
a moot point . . . Z12 would simplify your wiring.
Ed Godfrey
Posted: Mon Apr 10, 2017 5:35 pm Post subject: Circuit protection for backup alternator |
Bob,
I am using the SB1B-14 regulator.
Ed
contactor.
Bob . . . |
Posted: Tue Apr 11, 2017 7:31 am Post subject: Circuit protection for backup alternator |
At 08:33 PM 4/10/2017, you wrote:
Quote: | Bob,
I am using the SB1B-14 regulator. |
Okay . . . I'd recommend a Z-12 with
endurance bus. Much simpler in terms
of wire and not significantly less
robust.
Ed Godfrey
Posted: Tue Apr 11, 2017 7:44 am Post subject: Circuit protection for backup alternator |
Bob,
Thanks for the insight. I will review the Z12 ans see if I want to make the changes. Also, thank you to those others who offered up advice.
Ed
robust.
Bob . . . |
