mppalmer(at)aol.com Guest
Posted: Wed Apr 19, 2017 1:58 pm Post subject: Brake O-rings need replacing every now and then |
Wanted to remind everyone that the O-rings in the brake master cylinders (and the calipers) need replacing about every 10 years or so. (O-rings have a 15 year service life - from cure date. Probably less in hot climates.)
There are 3 O-rings in each brake master cylinder. Two are obvious - the third is buried inside the outer shell. It's the most critical. (There might be O-rings for the tube fittings too - I haven't gotten there yet.)
Might as well replace the O-rings on the brake calipers too, especially since we're free castering nose gear steering. (There's an AD on Cirrus aircraft for replacing those O-rings because you have to steer with brakes in a Cirrus too.)
And while speaking of cure dates, if you have a sight gauge for the header tank and/or if you have extended fuel tanks in the tips, you need to change out the rubber coupling hose(s) there about every 10 years too.
Mike Palmer <><
| | - The Matronics Glasair-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
CFCNX
Posted: Wed Apr 19, 2017 4:34 pm Post subject: Brake O-rings need replacing every now and then |
Thanks Mike.
