M14P Governor CSU correct Arm installation
dougsappllc(at)gmail.com
PostPosted: Mon Apr 24, 2017 7:50 am    Post subject: M14P Governor CSU correct Arm installation Reply with quote
Gov. install and adjustment fot the 285 hp HS6A engine is fully covered in the manual Maintenance and Service Instructions for Aero-engine HOUSAI-6
Best,
Doug
On Mon, Apr 24, 2017 at 12:40 AM, woodja51 <mwuillemin(at)mac.com (mwuillemin(at)mac.com)> wrote:
--> Yak-List message posted by: "woodja51" <mwuillemin(at)mac.com (mwuillemin(at)mac.com)>
The  nanchang governor is probably the same..as they have been since 1929... sternmotor etc...  basically rotate the governor shaft fully CW and the arm should be about in a position that has the ball joint
In line with the top of the governor unit .. then rotate it back about 60 degrees
And that should be about the high rpm limit.  Another 60 degrees CCW and that should be the low rpm limit... I think!
http://forums.matronics.com/viewtopic.php?p=468726#468726
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
