Cutting process and accuracy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
simmor2
PostPosted: Thu May 04, 2017 7:33 am    Post subject: Cutting process and accuracy Reply with quote
So I recently purchased some wood to start my build. It's rough cut 1x6x16ft
When it comes to cutting strips from the raw wood, is a table saw cut good enough?
The use of a planner and joiner, is it just acquiring the proper thickness with the plainer sufficient or is the joiner necessary as well?
For those of you who built from rough cut, what was the process you used to cut and finish a component before assembly?
Thanks for sharing your thoughts!
- Rich
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
glen
PostPosted: Thu May 04, 2017 8:02 am    Post subject: Cutting process and accuracy Reply with quote
Table saw fine if accurate. Measure twice cut once. NEW BLADE take your time. Worked for me. You're going to need lots more wood
- Rich
View user's profile Send private message Send e-mail Yahoo Messenger
jack(at)textors.com
PostPosted: Thu May 04, 2017 9:14 am    Post subject: Cutting process and accuracy Reply with quote
I rough cut with table saw then used my planer...
Jack Textor
- Rich
Brian.Jardine(at)Plexus.c
PostPosted: Thu May 04, 2017 10:17 am    Post subject: Cutting process and accuracy Reply with quote
Rich,
I cut all my own Sitka spruce from rough 1x6 and 2x6 boards. I used my jointer to get one side smooth, then cut everything with my table saw. I made everything 1/8" oversized, then ran them through my planer to get exact dimensions I needed. It took a little time but I enjoyed it.
Brian
Meridian, ID
bencharvet(at)gmail.com
PostPosted: Thu May 04, 2017 4:09 pm    Post subject: Cutting process and accuracy Reply with quote
Brian,
Where did you buy the rough cut Sitka?
Ben
On 5/4/2017 2:17 PM, Brian Jardine wrote:
Rich,
Brian
Meridian, ID
charlescampbell1924(at)gm
PostPosted: Fri May 05, 2017 3:12 am    Post subject: Cutting process and accuracy Reply with quote
I used rough lumber and sawed it with a table saw.  Everything worked well.  I don't even know what a joiner is.  Chuck
On Thu, May 4, 2017 at 11:31 AM, Comcast <4rcsimmons(at)comcast.net (4rcsimmons(at)comcast.net)> wrote:
--> Pietenpol-List message posted by: Comcast <4rcsimmons(at)comcast.net (4rcsimmons(at)comcast.net)>
- Rich
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
womenfly2
PostPosted: Fri May 05, 2017 4:32 am    Post subject: Re: Cutting process and accuracy Reply with quote
Band-saw = less waste. Then use a thickness sander to size material ... or planer.
I have one of these: Grizzly 12" Drum Sander P/N: G0459, excellent machine. Used it on my L-4 build too.
KAP
"The L-4 Project"
Visit my Pietenpol Web Site
PostPosted: Fri May 05, 2017 6:06 am    Post subject: Cutting process and accuracy Reply with quote
Ben,
MacBeath hardwoods in Salt lake city carries rough cut Sitka Spruce. I know they have a few locations.
Brian
Meridian, ID
paul(at)centralaero.nz
PostPosted: Fri May 05, 2017 11:03 am    Post subject: Cutting process and accuracy Reply with quote
I did the same, I started with an 8x8x16 foot long lump of timber, and the whole machine is made with a small bench saw, cheap bench planer and belt sander.
Paul Waterhouse
New Zealand
On 5/05/2017, at 11:12 PM, Charles N. Campbell <charlescampbell1924(at)gmail.com (charlescampbell1924(at)gmail.com)> wrote:
- Rich
WIKI -
tools
PostPosted: Mon Jun 12, 2017 10:35 am    Post subject: Re: Cutting process and accuracy Reply with quote
I'm in the bandsaw camp. Scribe a line, cut and plane. Joint remaining surface, lather rinse repeat.
I freehand accurately to a line, no jigs and such, not necessary.
Tools
bed(at)mindspring.com
PostPosted: Tue Jun 13, 2017 6:49 am    Post subject: Cutting process and accuracy Reply with quote
Tools
I wish I had a bandsaw that is worth a crap!. I had an old cheap saw that
you have to hold the wood at a 20 degree angle to cut down a line. I took it
to the dump and pushed it off the back of the truck. I finally gave up and
bought a RIGID brand for about $500. Now I have to hold the wood at about a
30 degree angle to follow a line. Totally worthless! I am considering buying
Carter Guides, but I might just be wasting my time and money installing
these on a Rigid saw. Any ideas or suggestions?
Barry
wheelharp
PostPosted: Tue Jun 13, 2017 12:38 pm    Post subject: Re: Cutting process and accuracy Reply with quote
I use a wood slicer blade from highland woodworking
http://www.highlandwoodworking.com/woodslicer12resawbandsawblades705to137.aspx
and found some tutorials on youtube for setting up for drift angle.
I guess the resaw blade is actually for resawing wide boards into very thin stock or making veneers, but I like the fact it is only .022 wide, so less waste...
Jon Jones
Ironton, MO
fastnaught(at)windstream.
PostPosted: Tue Jun 13, 2017 1:33 pm    Post subject: Cutting process and accuracy Reply with quote
Barry,
I think your problem is the blade and a tune up. I have had good success with either Carter or Timber wolf blades. Next check the tires on the big wheels. Then check tension on the blade. Make sure the blade is tracking correctly. Should be good after that. After all the saw is just a mechanism to spin the blade.
Good luck.
Jack
[quote] On Jun 13, 2017, at 10:46 AM, Barry Davis <bed(at)mindspring.com> wrote:
Tools
Barry
taildrags
PostPosted: Tue Jun 13, 2017 9:00 pm    Post subject: Re: Cutting process and accuracy Reply with quote
Jack; if you could make a YouTube video on how to make a bandsaw work the way they're supposed to, it would go viral. I've fiddled and fussed with the guides and wheels and knobs and adjustments on my (admittedly, inexpensive) bandsaw and I'm like Barry... nothing I do seems to make it want to cut straight and vertical unless I feed the stock into the blade so slowly that I might as well just use hand tools to do it. Even a jigsaw can cut vertical cuts, but they are hell on thin stock and once the jigsaw starts the stock chattering, I just force the blade through it with plenty of extra outside my cut line to get done and hope I can sand out the imperfections ;o) Can you understand why I don't work at NASA building space hardware, but build experimental low and slow aircraft instead? ;o)
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
cdawson5854(at)shaw.ca
PostPosted: Tue Jun 13, 2017 9:40 pm    Post subject: Cutting process and accuracy Reply with quote
https://www.youtube.com/watch?v=cQqq3rAZ4PI
Clif
workin' on Johnsons.
jawesma(at)gmail.com
PostPosted: Tue Jun 13, 2017 9:43 pm    Post subject: Cutting process and accuracy Reply with quote
I had a band saw, then sold it and got a Ryobi BT3000 table saw. Problems gone.Cut all my 1/4 x 1/2 rib stock, longerons and ply with it...everything, no extra sanding or planing.
I found it more versatile than the band saw.
JohnW
On 14 June 2017 at 13:00, taildrags <taildrags(at)hotmail.com (taildrags(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "taildrags" <taildrags(at)hotmail.com (taildrags(at)hotmail.com)>
Oscar Zuniga
Medford, OR
http://forums.matronics.com/viewtopic.php?p=470082#470082
WIKI -
taildrags
PostPosted: Wed Jun 14, 2017 8:52 pm    Post subject: Re: Cutting process and accuracy Reply with quote
I have a table saw, which is great for rips and straight cuts. The bandsaw would be for curved cuts.
Oscar Zuniga
Medford, OR
womenfly2
PostPosted: Thu Jun 15, 2017 5:09 am    Post subject: Re: Cutting process and accuracy Reply with quote
Watch this one: https://www.youtube.com/watch?v=wGbZqWac0jU
WF2
"The L-4 Project"
tools
PostPosted: Sun Jul 02, 2017 9:01 pm    Post subject: Re: Cutting process and accuracy Reply with quote
Barry,
I gotta just fly down and spend an afternoon with y'all. Guides are the least important part, any of them work fine. Blade selection and tension are the main players.
I resaw regularly with a 3/16 skip tooth blade on 14" saws up to six inches. Wide blades only work well on specialty or very heavy duty saws. The wood slicer works so well because of the thinness of the blade.
Tension is measured in lbs/in sq. the smaller the cross section of the blade, the smaller the denominator and therefore the higher the tension.
When is your next meeting?
Tools
aerocarjake
PostPosted: Wed Jul 05, 2017 11:02 am    Post subject: Re: Cutting process and accuracy Reply with quote
Thanks WF2, very helpful bandsaw setup video.....
Jake Schultz - curator,
Newport Way Air Museum (OK, it's just my home)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
