Making control horns
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
jerry(at)SKYCLASSIC.NET
PostPosted: Thu Jun 29, 2017 12:55 pm    Post subject: Making control horns Reply with quote
You have to kinda form the edges to get the thickness. You can tap them over
a pc of metal or some hard wood. Try to make an air foil. It is not an exact
science. Right now I am working on some dies that will stamp these out so
you get a perfect horn. My first attempt was a very nice part. I will post
some pictures soon. Only problem was the air foil was in the wrong
direction. Nice if your flying backwards. Live and learn. If it works out I
will have them for sale.
Jerry
Sky Classic Aircraft
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Pocono John
PostPosted: Thu Jun 29, 2017 2:48 pm    Post subject: Re: Making control horns Reply with quote
Thanks. I must have deleted my question while you were responding. I found two web pages that helped:
http://www.westcoastpiet.com/control_horns.htm
other site linked there.
John Cronin
pietflyer
PostPosted: Thu Jun 29, 2017 4:46 pm    Post subject: Making control horns Reply with quote
You've first got to bend the lending edges to a 1/4" radius, then edge weld
the two pieces. It is fairly simple and the easiest welding you will ever
do.
Jack Phillips
Pocono John
PostPosted: Thu Jun 29, 2017 4:57 pm    Post subject: Re: Making control horns Reply with quote
Thank you Jack.
John Cronin
Catdesigns
PostPosted: Thu Jun 29, 2017 10:55 pm    Post subject: Making control horns Reply with quote
My method
Chris
Sent from Yahoo Mail on Android
[quote] On Thu, Jun 29, 2017 at 1:55 PM, JERRY
<jerry(at)SKYCLASSIC.NET> wrote:
--> Pietenpol-List message posted by: "JERRY" <jerry(at)skyclassic.net (jerry(at)skyclassic.net)>
Jerry
Chris
Sacramento, CA
WestCoastPiet.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
