Bolts for torque tube
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
Pocono John
PostPosted: Sat May 06, 2017 3:19 pm    Post subject: Bolts for torque tube Reply with quote
What size bolts did you use to secure the torque tube brackets to the floor? I'm making the flight control pieces now, so any help with the hardware used will sure be appreciated.
Thank you!
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
John Cronin
taildrags
PostPosted: Sun May 07, 2017 7:50 pm    Post subject: Re: Bolts for torque tube Reply with quote
John;
I was surprised to not find those called out on the plans, but I can't imagine that anything more than AN3s would be required there. I'm pretty sure that's what is on my airplane, although I can't find any photos that show that. The photos that I have of Ernie Moreno's airplane sure do look like AN3s holding down those brackets. As I say, there isn't a lot of load on that particular part. The tricky part is securing the bolt head to the underside of the floor, if you do them the way the plans call for. The photo of Ernie's airplane seems to indicate that his uses nutplates under the floor so the bolts go in from the cockpit side (top):
http://www.flysquirrel.net/piets/control01.jpg
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
Catdesigns
PostPosted: Sun May 07, 2017 9:04 pm    Post subject: Bolts for torque tube Reply with quote
I used AN4 bolts
Chris
Sacramento, CA
Sent from Yahoo Mail on Android
On Sun, May 7, 2017 at 8:51 PM, taildrags
<taildrags(at)hotmail.com> wrote:
--> Pietenpol-List message posted by: "taildrags" <taildrags(at)hotmail.com (taildrags(at)hotmail.com)>
John;
Oscar Zuniga
Medford, OR
Air Camper NX41CC &quot;Scout&quot;
http://forums.matronics.com/viewtopic.php?p=469094#469094
http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution====================
Chris
Sacramento, CA
WestCoastPiet.com
oldbird
PostPosted: Sun May 07, 2017 11:03 pm    Post subject: Re: Bolts for torque tube Reply with quote
Hi all
I used M5 bolts to fix the Castamide bearing blocks to the floor. AN3 bolt is 3/16" which is 4.8mm. Very close. I used stainless T-nuts under the floorboard to facilitate removal if necessary. Epoxy the nuts in place, use Loctite 243 for vibration control. Please see my building log: www.mykitlog.com/oldbird
Happy building & flying
Semih Oksay
Still building in Istanbul, Turkey
Rear turque tube bearing
 Filesize:  91.49 KB
 Viewed:  1971 Time(s)
cdawson5854(at)shaw.ca
PostPosted: Sun May 07, 2017 11:31 pm    Post subject: Bolts for torque tube Reply with quote
Shear strength of an an3 bolt is over 2000lb. You have two at each end.
How strong did you say you were?
91% done, only 89% to go! Smile
Clif
Bacon - The duct tape of the kitchen.
I used AN4 bolts
Chris
Sacramento, CA
charlescampbell1924(at)gm
PostPosted: Mon May 08, 2017 3:37 am    Post subject: Bolts for torque tube Reply with quote
Yes, I used AN3 bolts
On Sun, May 7, 2017 at 11:50 PM, taildrags <taildrags(at)hotmail.com (taildrags(at)hotmail.com)> wrote:
John;
Oscar Zuniga
Medford, OR
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
Pocono John
PostPosted: Mon May 08, 2017 5:23 am    Post subject: Re: Bolts for torque tube Reply with quote
Thanks everyone. I appreciate the help.
John C
John Cronin
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
