jpoint(at)wi.rr.com Guest
Posted: Sun May 07, 2017 1:59 pm Post subject: Z-17 and over voltage warning lamp |
I've wired my airplane based on the Z-17 diagram, which uses no master
contactor, a PM alternator and crowbar OV adapted for that alternator.
Notably, Z-17 omits the panel mounted OV warning lamp which is activated
by the OV relay being tripped- the lamp is wired to the normally closed
contact on the relay, as shown on the diagram which came with the
alternator.
Today I applied power to the panel for the first time, and while no
spoke escaped, I now know why Z-17 omits this lamp- without a master
contactor, this lamp is illuminated constantly when the master switch is
off and only goes off when power is applied to the alternator control
relay. I would like to use this lamp on the panel, but the only fix I
can noodle out is to run the lamp wire through a switch, probably using
a 3-pole for the master switch (which now controls both battery and
alternator on one switch.)
Has anyone else tackled this with a different solution?
Jeff Point
Milwaukee
Posted: Sun May 07, 2017 4:44 pm Post subject: Z-17 and over voltage warning lamp |
At 04:57 PM 5/7/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com>
I've wired my airplane based on the Z-17 diagram, which uses no master contactor, a PM alternator and crowbar OV adapted for that alternator.
Notably, Z-17 omits the panel mounted OV warning lamp which is activated by the OV relay being tripped- the lamp is wired to the normally closed contact on the relay, as shown on the diagram which came with the alternator.
Today I applied power to the panel for the first time, and while no spoke escaped, I now know why Z-17 omits this lamp- without a master contactor, this lamp is illuminated constantly when the master switch is off and only goes off when power is applied to the alternator control relay. I would like to use this lamp on the panel, but the only fix I can noodle out is to run the lamp wire through a switch, probably using a 3-pole for the master switch (which now controls both battery and alternator on one switch.)
Has anyone else tackled this with a different solution? |
Z-17 has a recommended solution. Active notification
of low voltage in the form of sensor and light.
Eric Jones has a LV Warn product http://tinyurl.com/yj7g5jh
I'll have a replacement for the discontinued AEC9005
product later this year.
You can built your own from details on my website.
http://tinyurl.com/6mvso29
No doubt there are other options out there.
Joined: 28 Mar 2008 Posts: 1908 Location: Riley TWP Michigan
Posted: Sun May 07, 2017 6:02 pm Post subject: Re: Z-17 and over voltage warning lamp |
Perhaps a LED (with series resistor) in parallel with the 5 amp circuit breaker.
_________________ Joe Gores |
Posted: Mon May 08, 2017 8:14 am Post subject: Z-17 and over voltage warning lamp |
At 09:02 PM 5/7/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
Perhaps a LED (with series resistor) in parallel with the 5 amp circuit breaker. |
Excellent thought . . . only one concern . . .
and it's a minor one. Current demand by any
light connected across the breaker should be
LESS than the dropout current for the relay.
I have some exemplar S704 plastic relays here
on which I've measured a dropout current on
the order of 0.04 amps. This might be a good
application for the indicator lamp I just
featured on my 'trivia dump'. It draws
0.012 amps at 12v.
If you'd like to try this lamp, shoot me an
address and I'll mail you one.
Posted: Mon May 08, 2017 4:41 pm Post subject: Z-17 and over voltage warning lamp |
Thanks Bob. Thinking this through some more- since I have an engine monitor with alarms and setable limits, I could simply have an alarm trigger when voltage drops below a certain point, say 14 volts, indicating an alternator out and battery only operations. A check of the alt circuit breaker could diagnose if the condition was caused by a crowbar trip or some other failure... although in flight it makes little difference since your on battery power either way.
Is there any real advantage to having a dedicated OV trip warning light? I can't seem to find any.
Jeff
On May 7, 2017, at 7:43 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | At 04:57 PM 5/7/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com (jpoint(at)wi.rr.com)>
Posted: Tue May 09, 2017 5:50 am Post subject: Z-17 and over voltage warning lamp |
At 07:38 PM 5/8/2017, you wrote:
Quote: | Thanks Bob. Thinking this through some more- since I have an engine monitor with alarms and setable limits, I could simply have an alarm trigger when voltage drops below a certain point, say 14 volts, indicating an alternator out and battery only operations. A check of the alt circuit breaker could diagnose if the condition was caused by a crowbar trip or some other failure... although in flight it makes little difference since your on battery power either way.
Is there any real advantage to having a dedicated OV trip warning light? I can't seem to find any. |
As long as you have ACTIVE notification of some
type, the design goal is met.
Most span-can drivers don't know their alternator
is off line until stuff on the panel starts going
dark. You need to know . . . and implement plan-B
within mere minutes . . . there are lots of ways
to make that happen.
