victorbravo(at)sbcglobal. Guest
Posted: Mon May 08, 2017 10:51 am Post subject: Tailwheel Strut |
And yet another technical question for the experienced Kolbers...
I have seen messages on the list about the use of several different materials for the tailwheel "stinger" spring. I believe I've seen posts about fiberglass, steel, and aluminum having been tried.
My Firestar has a tailwheel spring that may be fiberglass. There are no visible fasteners (bolts, rivets, etc) holding it into either the fuselage sub-fin or the tailwheel unit. I recently read that some of the springs were fiberglass rods that were glued in with epoxy instead of bolted. From what I have read, the fiberglass is not the best choice. So if mine is fiberglass, I'm guessing I should replace it.
So now... this big question! Does anyone on the Kolb list know if it is more or less desirable to use 7075-T6 aluminum, or 4130 / 4340 steel, or some other material, based on weight versus durability versus shock absorption?
The reason I am asking this is that I have a good piece of 7075-T6 material available (the old original Kolb aluminum gear leg that I removed). This material is used on a very large number of aircraft landing gear legs, both FAA certified and experimental. It is the preferred material used by the #1 manufacturer of aircraft landing gear in the world (Grove Aircraft).
What is the consensus among the experienced Kolbers about 7075-T6 used for the tail spring? Does it work well... does it break... is it the best balance between weight and strength... have all the people who used 7075 broken them and replaced them with steel????
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
gdhelton(at)gmail.com Guest
Posted: Mon May 08, 2017 2:53 pm Post subject: Tailwheel Strut |
Well Bill, it is really a matter of personal preference. I haven't had a lot luck with the original fiberglass rod. I had two fail. Both failed in the trailer sitting static. Go figure. I've gone with new Kolb 7075-T5 rod and new breakaway tailwheel assembly
on my original Firestar it's a nice setup. Using a old landing gear leg would require a lot of machining I would think? But if you've got that kind of equipment I guess that is an option. I know some guys like to use a heat treated 4130 steel tube. I went with the aluminum only because I'd personally rather bend the rod before possibly damaging the rudder post and its weldments. Anyway, that's all my thoughts. I'm sure there are people on here with theirs too.
George H.
Firestar 1 #FS100
14GDH
Mesick, Michigan
Have a great day!
Quote: | On May 8, 2017, at 2:51 PM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Bill Berle
Posted: Mon May 08, 2017 3:12 pm Post subject: Tailwheel Strut |
Thanks George, I'm trying to gather a consensus of people's experience with aluminum and steel. I have read about John H's preference for 4130 heat treated steel. I'm trying to get everyone else's opinion to have a fair comparison.
I happen to have this chunk of 7075 for free, so if it is a good material then it saves me the time/cost/shipping of buying material. If it is not a good material to use then of course any cost and time savings doesn't mean much.
Bill Berle
On Mon, 5/8/17, George Helton <gdhelton(at)gmail.com> wrote:
Subject: Re: Tailwheel Strut
Date: Monday, May 8, 2017, 3:52 PM
George H.
Firestar 1 #FS100
14GDH
Mesick, Michigan
Have a great day!
wrote:
> --> Kolb-List message posted
by: Bill Berle <victorbravo(at)sbcglobal.net>
absorption?
> Bill Berle
> www.grantstar.net
for-profit entities
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
- MATRONICS WEB FORUMS -
via the Web Forums!
- NEW MATRONICS LIST WIKI -
Email List Wiki!
- List Contribution Web Site -
support!
ceengland7(at)gmail.com Guest
Posted: Mon May 08, 2017 3:58 pm Post subject: Tailwheel Strut |
For another data point, the original Twinstar I'm restoring appears to
have a fiberglass tailspring. It's s/n22, 1st registered in 1985. No
idea on how many hours are on it, but the guy I bought it from has
always flown a lot, so it likely has quite a few hours.
It doesn't appear to have any sag, and it's standing up fine so far for
me, but I'm just rolling the bare fuselage around the shop right now.
Charlie
Bill Berle
George H.
Firestar 1 #FS100
14GDH
Mesick, Michigan
Have a great day!
absorption?
> Bill Berle
