154hp Rotax "914"
jan_de_jong(at)casema.nl
PostPosted: Mon May 08, 2017 3:04 pm    Post subject: 154hp Rotax "914" Reply with quote
via pprune:
https://www.youtube.com/watch?v=UqZLsHa2XSE
and less expensive, and lighter, and no carburetors
seems a little ambitious? and what does the propeller say..
Jan de Jong
peterz(at)zutrasoft.com
PostPosted: Mon May 08, 2017 4:13 pm    Post subject: 154hp Rotax "914" Reply with quote
Neat.....
I guess the obvious question is one of longevity and shrink-fit crankshaft capacity?
The 915iS looks great though....if it isn't priced out of this world.
Pete
A239
On May 8, 2017, at 6:47 PM, Jan de Jong <jan_de_jong(at)casema.nl> wrote:
via pprune:
Jan de Jong
PostPosted: Tue May 09, 2017 3:49 am    Post subject: 154hp Rotax "914" Reply with quote
Actually, in the video it is explained that the crankshaft is welded
together with a special tool...
They strike me as a competent outfit. Still, 154hp seems a little over
the top.
915iS is probably too heavy for the Europa.
Jan de Jong
On 5/9/2017 2:12 AM, Pete wrote:
Neat.....
Pete
A239
> via pprune:
> Jan de Jong
flyingphil2
PostPosted: Wed May 10, 2017 12:31 am    Post subject: Re: 154hp Rotax Reply with quote
I understand that the UK EuroFox agents are working with Rotax to develop a variant of the 912 ULS that will deliver a constant 120hp. Last time I heard they were up to 115hp but still had some more things to try. I believe that this involves modifying the standard 912 ULS with new parts and revised engine mapping. Their motivation for this is to give the EuroFox tug a bit more grunt but I imagine it would work very well in a Europa too. They plan to have a demonstrator flying by July this year.
Phil
rampil
PostPosted: Thu May 11, 2017 4:40 am    Post subject: Re: 154hp Rotax Reply with quote
Phil,
Just curious:
How do you do "engine mapping" in a 912uls which has carburetors, not fuel injection, and no electronic ignition, but rather a fixed wheel providing timing?
Ira N224XS
paul.the.aviator(at)gmail
PostPosted: Thu May 11, 2017 12:35 pm    Post subject: 154hp Rotax "914" Reply with quote
Ira,
Tongue in cheek..... I can only assume that there has been a break through in automotive technology that we are not aware of for this. ☺
Seriously though, it was an  nice presentation and it reminds me of Jason Parker's work 10 years back. It did occur to me that there probably isn't a propeller available for a Rotax in this HP range.
Also, I couldn't help thinking about the possibility of stress fractures in the crankshaft if they are welding the press fit to prevent twisting.
Paul
On Thu, May 11, 2017 at 7:40 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Phil,
Just curious:
Ira N224XS
flyingphil2
PostPosted: Fri May 12, 2017 1:00 am    Post subject: Re: 154hp Rotax Reply with quote
Ira,
You spotted my deliberate mistake Wink
It's a development of the standard 912 iS.
Phil
