DIe Spring gear
Goto page Previous  1, 2
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
steven.d.dortch(at)gmail.
PostPosted: Fri May 12, 2017 10:31 am    Post subject: DIe Spring gear Reply with quote
Terry, my interests are in what size Heim bearings you used.
Man thanks for the help.
Blue Skies,
Steve D
On Fri, May 12, 2017 at 12:32 PM, jarheadpilot82 <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "jarheadpilot82" <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)>
I am currently out of the country, but will be back tomorrow. I will try to get some measurements together over the weekend and post them.
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=469247#469247
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
Blue Skies,
Steve D
- The Matronics Pietenpol-List Email Forum -
jarheadpilot82
PostPosted: Fri May 12, 2017 8:15 pm    Post subject: Re: DIe Spring gear Reply with quote
wilco.
Semper Fi,
Terry Hand
Athens, GA
jarheadpilot82
PostPosted: Sun May 14, 2017 7:20 pm    Post subject: Re: DIe Spring gear Reply with quote
Look at the pictures below and these measurements, hopefully, will make sense -
The die spring "can" is made of 2.25 inch diameter tubing.
The die spring rod is 1" in diameter.
The various metal plates are 0.125 thick
The diagonal tubing above the plate in the center top of the gear is 0.75 in diameter. The streamline tubing between these two tubes is approximately 1.5 inches in depth.
The gear legs - the front tubes are 1.25 in diameter, and the rear tubes are 1.125 in diameter.
The bolt at the top of gear legs is, I believe an AN4, and the bolt down by the axle is an AN6
I hope that all this is useful. Oh, and the aircraft attitude is about 12º.
P.S. Don't tell me that the metal is rusty and I need to wipe it down. The pictures were taken a couple of days after driving through a rain storm with the fuselage on an open trailer. I wiped it down with preservative after the pictures were taken. Honest.
 Filesize:  2.12 MB
 Viewed:  1456 Time(s)
 Filesize:  2.72 MB
 Filesize:  2.44 MB
Semper Fi,
Terry Hand
Athens, GA
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 2 of 2
