jonboede(at)hotmail.com Guest
Posted: Tue May 09, 2017 10:22 am Post subject: brake metering valve |
In the CJ:
If I put the rudder pedals full left or full right and squeeze the brake handle I hear the brake system fill and then all the noises stop.
If I put the rudder pedals to the middle position and squeeze, there's an on-going pneumatic noise that I'm not quite able to describe.
Probably means my QS-2 brake metering valve is in need of TLC, yes? I see that there's an overhaul kit for it... is that something that takes well to an overhaul or best to just get a whole new valve?
Jon
Posted: Tue May 09, 2017 11:19 am Post subject: brake metering valve |
Yes. Order the rebuild kit from Doug. Shouldn't need a new one unless it's horribly corroded.
Dennis
On May 9, 2017, at 2:20 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
In the CJ:
Jon
jackpot
Joined: 13 Jul 2010 Posts: 65 Location: Las Vegas, Nevada
Posted: Wed May 10, 2017 8:24 am Post subject: brake metering valve |
Jon. It is an easy job. Just resealed mine. Just be careful when you take it apart so you can put the parts back in the correct position internally. Removing it from Acft , unscrew both air lines from valve remove two bolts and it comes right of airplane. Same to reinstall. I think Doug Sapp has the seal kits. I also inSTALLED a new drain valve in the snot bottle in the belly that is associated with the brake system. Have fun. Gary. CJ N22YK. LAS
On May 9, 2017, at 11:20, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
In the CJ:
Jon
