Rebel56
Posted: Mon May 15, 2017 2:24 pm Post subject: Radio static when using 12 volt lighter power plug |
Obviously I have not grounded something properly, but I am at a loss.
I have two cigarette lighter plugs wired into my aircraft. They are to provide power to my iPad on longer flights. I have noticed that whenever I have the iPad plugged in I get some static when I receive a transmission. Otherwise the radio is quiet. Not sure what to make of this. Why is it only on receiving? I would think that if it was a ground issue, I would have the static all the time.
If there is nothing plugged into the power plug, I have no issues at all.
Any ideas as to what I should check first.
Rebel56
fherr(at)cfl.rr.com Guest
Posted: Mon May 15, 2017 3:12 pm Post subject: Radio static when using 12 volt lighter power plug |
I suggest you check your battery first (age, charge level, capability to take a charge). You could be pushing it over the limit and may not hear any issue when transmitting.
Easy checks that could solve the issue.
Francis
Rebel56
http://forums.matronics.com/viewtopic.php?p=469331#469331
swperk
Posted: Mon May 15, 2017 3:25 pm Post subject: Re: Radio static when using 12 volt lighter power plug |
Can you manually open the squelch on your receiver? If so, is the noise present when there is no transmission being received? If so, I suspect that the adapter that powers your iPad is emitting lots of RF noise and it's time to find a better one. I had the same problem with my plane, but mine was so bad that it was noisy enough to break the squelch on its own.
gi(at)av8r.de Guest
Posted: Mon May 15, 2017 8:46 pm Post subject: Radio static when using 12 volt lighter power plug |
unfortunately there are a lot of those cheap USB power adapters for lighter plugs on the market. A lot of them are producing RF interference. I have had the same problems. You have to try a few until you find one that is not causing RF interference.
Am 16.05.2017 um 00:24 schrieb Rebel56 <Rebel56(at)rogers.com>:
Rebel56
