Radio static when using 12 volt lighter power plug
Rebel56
PostPosted: Mon May 15, 2017 2:21 pm    Post subject: Radio static when using 12 volt lighter power plug Reply with quote
Obviously I have not grounded something properly, but I am at a loss.
I have two cigarette lighter plugs wired into my aircraft. They are to provide power to my iPad on longer flights. I have noticed that whenever I have the iPad plugged in I get some static when I receive a transmission. Otherwise the radio is quiet. Not sure what to make of this. Why is it only on receiving? I would think that if it was a ground issue, I would have the static all the time.
If there is nothing plugged into the power plug, I have no issues at all.
Any ideas as to what I should check first.
Rebel56
rene(at)felker.com
PostPosted: Mon May 15, 2017 2:38 pm    Post subject: Radio static when using 12 volt lighter power plug Reply with quote
It is the iPad power adapter. Lot of discussion on this and other boards
about good and bad adapters. I have played with a couple and found one that
was better than the others......but my kids keep stealing and moving them.
I just live with it and only plug in the iPad when I need it.
Rene'
801-721-6080
