The Kapler/Zuniga hinge on a steel tube fuselage
Goto page Previous  1, 2
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
wheelharp
PostPosted: Tue May 23, 2017 12:35 pm    Post subject: Re: The Kapler/Zuniga hinge on a steel tube fuselage Reply with quote
Somewhat on the same subject...since the location of this hinge half is done pre-covering, does the thickness of covering on fuselage and horizontal and vertical stab add enough thickness to make alignment off? In other words, does any allowance need to be made for covering, or is it insignificant enough it doesn't matter.
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Jon Jones
Ironton, MO
aerocarjake
PostPosted: Tue May 23, 2017 2:50 pm    Post subject: Re: The Kapler/Zuniga hinge on a steel tube fuselage Reply with quote
good point... it may not be critical but my horizontal stabilizer is mounted on washers and I could adjust them if needed. I suspect that will be one of the many things that crop up when one re-assembles the plane after covering/paint.... I guess I'll just skip the covering altogether - ha!
Jake Schultz - curator,
Newport Way Air Museum (OK, it's just my home)
jarheadpilot82
PostPosted: Tue May 23, 2017 5:07 pm    Post subject: Re: The Kapler/Zuniga hinge on a steel tube fuselage Reply with quote
Jake,
A picture is worth a thousand words (maybe two thousand for this air line pilot).
Thanks!
Semper Fi,
Terry Hand
Athens, GA
taildrags
PostPosted: Tue May 23, 2017 7:07 pm    Post subject: Re: The Kapler/Zuniga hinge on a steel tube fuselage Reply with quote
Jake-! Long time no hear progress report. I was expecting to see a cloud of blue smoke from your radial engine on the horizon north of me when you fired it up.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
aerocarjake
PostPosted: Tue May 23, 2017 7:17 pm    Post subject: Re: The Kapler/Zuniga hinge on a steel tube fuselage Reply with quote
I should probably cover the plane before I fly in....
 Filesize:  2.35 MB
 Viewed:  1527 Time(s)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 2 of 2
