Prop cover plate
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
Rick Schreiber
PostPosted: Tue May 23, 2017 7:37 am    Post subject: Prop cover plate Reply with quote
I'm thinking about having a number of prop cover plates made with an acid etched design on the surface. This is just a thin cover plate meant to be used over a standard steel or aluminum prop plate. The diameter will be around 6" and made for a SAE-1 bolt pattern as used on a corvair prop hub. I need to run at least 25 of these to make it worthwhile. The cost is about $10 each. If there is enough interest I will have these made. Just send me a pm at lmforge at earthlink.net if interested. The attached picture is a paper print of the graphic taped to the front of my Piet/corvair. The plate will be marked for the prop bolt holes but will not be drilled or cut out. I want to get these done before Brodhead so I'll need to hear from those interested soon.
Rick Schreiber
NX478RS
Valparaiso, IN
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
 Filesize:  45.4 KB
 Viewed:  1083 Time(s)
taildrags
PostPosted: Tue May 23, 2017 7:06 pm    Post subject: Re: Prop cover plate Reply with quote
Nice design! I'm guessing the Ford builders will be especially interested in these for the period look that they impart. My A75 sports a thin aluminum reproduction of the original Continental plate, which I think I got from Wag Aero or someplace. I don't remember what it cost. It, too, is decorative and goes over the real crush plate. Obviously, those who are using tapered shaft prop hubs will be out of luck with something like this, although I guess you could also design a plate with the graphics positioned around where the nose of the hub pokes through.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
Rick Schreiber
PostPosted: Thu May 25, 2017 3:46 pm    Post subject: Re: Prop cover plate Reply with quote
Thanks for the compliment Oscar. So far the response has been pretty good. I may wind up doing more than 25 so I will have enough to take to Brodhead.
Rick Schreiber
NX478RS
suttonmark56(at)gmail.com
PostPosted: Thu May 25, 2017 6:22 pm    Post subject: Prop cover plate Reply with quote
On Thu, May 25, 2017 at 7:49 PM Rick Schreiber <lmforge(at)earthlink.net (lmforge(at)earthlink.net)> wrote:
--> Pietenpol-List message posted by: "Rick Schreiber" <lmforge(at)earthlink.net (lmforge(at)earthlink.net)>
Rick Schreiber
NX478RS
http://forums.matronics.com/viewtopic.php?p=469610#469610
I would love to purchase one from too if you have enough
Mark Sutton
678/283-4250
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
