victorbravo(at)sbcglobal. Guest
Posted: Wed May 31, 2017 9:53 am Post subject: 3 questions on aileron authority |
Last night I completed the structural repairs to the two wing ribs we bent on Saturday. It was possible to replace the damaged upper rear tube "rib cap" sections, without removing the rest of the rib form the spar. Internal sleeves were fabricated to allow the replacement section to be spliced in structurally with two rivets, yielding a continuous rib cap from leading to trailing edge. I'm almost ready to recover the wingtip and am deciding whether to patch the aileron fabric or recover the entire aileron.
I have a few questions I want to ask the experienced Kolb owners... Jimmy and I are desperately trying to identify the root cause of the control problem we had.
1) Have any of you experienced a situation where the aileron controls have X amount of friction (or control authority) in one direction, and 3X in the other direction? What was the cause of this?
2) I located several photos online of Kolb Mark 3 aircraft that had no flaps. Did the versions of the Mk/3 without flaps suffer from the same heavy aileron forces as the versions with flaps?
3) The Kolb instructions/blueprints that I have seen (Firestar) show that you are supposed to install the hinges with the hinge axis in the center of the gap between the wing and aileron. They telly ou to put the hinge into a "V" shape and i nstall them, as opposed to the hinges being "flat". This particular Mark 3 has the hinge axis (pin) not exactly in the center of the gap. Does anybody know whether this would or would not make the ailerons more or less difficult?
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
On Wed, 5/31/17, M. Domenic Perez <perezmdomenic(at)plateautel.net> wrote:
Subject: 3 axis control authority
Date: Wednesday, May 31, 2017, 9:19 AM
When I first got my
Firestar II, my instructor test flew it first and commented
that my ailerons “were crap”. I had bought the
plane used and was disappointed that I might have bought a
poorly built one. However, simply disassembling the joystick
mixer, cleaning the metal-to-metal surfaces that are in
contact during control movements, lubricating and being
careful not to overtighten the nuts putting it back together
“made all the difference in the world”, he said.
So I never personally experienced the heavy aileron problem
on my own plane, I’m just relaying what the instructor
thought, before mixer maintenance and after. Bill Berle,
something to think about on your friend’s Mk III if
you haven’t already. Haven’t
contributed to the list or even flown for a while. Life can
get complicated.
M. Domenic
PerezFS II 503Vaughn, NM
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Wed May 31, 2017 10:07 am Post subject: 3 questions on aileron authority |
Bill- While you have the aircraft down on the ground, check for the resistance right and left. Then disconnect pieces one at a time until you find the culprit. Yes, I have seen things that move freely in one direction and not the other. Disconnect the ailerons and see if it's a hinge doing it, too. It almost sounds like something is binding by going "over center", and you are trying to bend something to make it go back.
Bill Sullivan
lcottrell
Joined: 29 May 2006 Posts: 1490 Location: Jordan Valley, Or
Posted: Wed May 31, 2017 10:20 am Post subject: 3 questions on aileron authority |
Bill I would suggest that you first make sure that the conversion to
dual sticks was done correctly.
Larry
On Wed, May 31, 2017 at 12:06 PM, william sullivan
<williamtsullivan(at)att.net> wrote:
Bill Sullivan
If you forward this email, or any part of it, please remove my email
address before sending.
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Wed May 31, 2017 3:56 pm Post subject: Re: 3 questions on aileron authority |
Don't know if this will be any help but here is how the ailerons are supposed to be attached and aligned: http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html
Note especially pages 19 & 23.
Also I reinforced the aileron pivots at the tip ends to keep everything aligned: http://oh2fly.net/oldpoops/pg8.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
baberdk
Joined: 23 Jan 2014 Posts: 53 Location: East Moline, Il
Posted: Thu Jun 01, 2017 4:03 am Post subject: 3 questions on aileron authority |
Bill,
Check to see if the 2x2 wood spacer is between the gas tanks.
Respectfully,
Dennis Baber
Stay Curious
Posted: Thu Jun 01, 2017 7:01 am Post subject: 3 questions on aileron authority |
This Kolb has a custom 25 gallon tank that is different than the standard fuel jugs.
Bill Berle
On Thu, 6/1/17, Denny Baber <baberdk(at)gmail.com> wrote:
Subject: Re: 3 questions on aileron authority
Date: Thursday, June 1, 2017, 5:03 AM
Bill, Check to
tanks.
Respectfully,
Dennis Baber
Stay Curious
gdhelton(at)gmail.com Guest
Posted: Thu Jun 01, 2017 10:39 am Post subject: 3 questions on aileron authority |
25 Gallons! Wow, that's a lot of weight. Did he do a C.G. On the plane full fuel , coolant and at least to average weight (170#) pilot and passenger?
George H.
Have a great day!
Quote: | On Jun 1, 2017, at 10:57 AM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Bill Berle
Bill, Check to
tanks.
Respectfully,
Dennis Baber
Stay Curious
Posted: Thu Jun 01, 2017 10:48 am Post subject: 3 questions on aileron authority |
157.5 pounds just in fuel. What engine is he running, 582, 912 or something different? Aft C.G. could cause all kinds of weird handling problems. It wouldn't account for the control force problems though. I wouldn't think anyway. Anyway, for what it's worth. George H.
Have a great day!
Bill Berle
Bill, Check to
tanks.
Respectfully,
Dennis Baber
Stay Curious
Posted: Thu Jun 01, 2017 11:07 am Post subject: 3 questions on aileron authority |
I have no idea on the weight and balance. The aircraft flew "well enough" to convince me that the weight and balance was not the cause of this particular problem. The problem I am referring to is on the longitudinal (roll) axis, not the pitch axis.
We have a major problem with one of the primary flight controls, and I am looking for assistance and opinions on why a Kolb would be slightly difficult to roll left, and very difficult to roll right.
The pitch and yaw response was well within the acceptable range.
Bill Berle
Date: Thursday, June 1, 2017, 11:35 AM
George H.
Have a great day!
wrote:
> --> Kolb-List message posted
by: Bill Berle <victorbravo(at)sbcglobal.net>
> Bill Berle
> www.grantstar.net
for-profit entities
wrote:
> Subject: Re: 3
> To: kolb-list(at)matronics.com
AM
> Bill, Check to
between the gas
> tanks.
> Respectfully,
> Dennis Baber
> Stay Curious
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
- MATRONICS WEB FORUMS -
via the Web Forums!
- NEW MATRONICS LIST WIKI -
Email List Wiki!
- List Contribution Web Site -
support!
