		byoungplumbing(at)gmail.c Guest
				 Posted: Thu Jun 01, 2017 1:07 pm    Post subject: New from Utah |
				How is the flying coming,,,, did you change the gear box or prop?
 Boyd  mkiii
  Brigham city Utah
 On Feb 6, 2017 8:39 AM, "Wayne Schneider" <jwaynes(at)gmail.com (jwaynes(at)gmail.com)> wrote: 	  | Quote: | 	 		  Hello fellow fliers,
 I've been lurking here for a few months and thought I should introduce myself.  Name is Wayne Schneider and I live in Utah where the air is thick and cold, lol.
 Last summer I purchased N359RT which is a modified Twinstar Mark II with a Rotax 532.  Yes, you read that correctly, it's the predecessor to the 582.  SIngle ignition but otherwise very much the same.
 Unfortunately, it has a WarpDrive propeller whose MMI is too much for the A gearbox so I'll be swapping that out before summer.  And, I need to do a complete inspection.  Does anybody need a slightly used 3 blade 68" prop?
 New guy,
 Wayne
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Richard Pike
				 Posted: Fri Jun 02, 2017 4:49 am    Post subject: Re: New from Utah |
				Back when I had a 532 on my MKIII, I found it worked really well with a two blade 66" Ivo. Initially I had a three blade 64" Ivo and that was just too much prop for the somewhat pipey 532. Took away one of the blades and it ran really happy, enough so that I could go to the next longer size Ivo, and that worked good too.
 Then I replaced the points ignition with one of Airscrew Performance's CDI ignition systems and was pleased with it.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		roy.spangler(at)kirtland. Guest
				 Posted: Wed Jun 07, 2017 12:09 pm    Post subject: New from Utah |
				New Guy,
 Is it a ground adjustable prop ?
 Roy
 spangler(at)kirtland.edu (spangler(at)kirtland.edu)
 On Thursday, June 1, 2017, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
 Boyd  mkiii
  Brigham city Utah
 On Feb 6, 2017 8:39 AM, "Wayne Schneider" <[url=javascript:_e(%7B%7D,'cvml','jwaynes(at)gmail.com');]jwaynes(at)gmail.com[/url]> wrote: 	  | Quote: | 	 		  Hello fellow fliers,
 New guy,
 Wayne
