klixon cb
rogsherriff(at)hotmail.co
PostPosted: Thu Jun 08, 2017 12:20 pm    Post subject: klixon cb Reply with quote
I notice that the top terminal on the klixon circuit breakers is marked "line." Does it matter on which terminal the bus or the LRU go?
Roger.
PostPosted: Thu Jun 08, 2017 3:34 pm    Post subject: klixon cb Reply with quote
No.
alec(at)alecmyers.com
PostPosted: Thu Jun 08, 2017 4:35 pm    Post subject: klixon cb Reply with quote
I just had an issue with recharging a flat aircraft battery by running the engine after a hand start. Not enough residual battery juice to close the main contactor, so no current flowing from the alternator to the battery.
Come to think of it it might be a generator instead of an alternator because even without a power source for excitation the bus was powering the aircraft radio. Still, no current going to the battery with the contactor resolutely open.
Is this a really obvious well known phenomenon that I've never really thought about before?
On Jun 8, 2017, at 16:19, Roger Sherriff <rogsherriff(at)hotmail.com (rogsherriff(at)hotmail.com)> wrote:
Roger.
PostPosted: Thu Jun 08, 2017 6:56 pm    Post subject: klixon cb Reply with quote
Waaayyy back in the dark ages . . . but after Lucky Lindy,
only generators were considered to be 'self exciting' but
then only if the field was 'flashed' so as to possess some
residual magnetism. Alternators too had some non-zero
retentivity but generally too low to bring an alternator
on line at ordinary speeds.
There WERE notable exceptions. Alternators on the Bonanzas
and Barons were expected to self excite at cruise rpms . . .
and most did . . . but that's an interesting story for another
time.
Today's alternators, PARTICULARLY those that run nearly 10k
rpm on the front of a Lycoming will come on line self excited
if lightly loaded . . . and will run well. So your observation
may not be a strange as you would think.
Having said that, it's generally a poor idea to recharge
a flat battery with the ship's alternator . . . use
jumper cables to an automobile for a few minutes to stir
up the battery's chemistry and avoid unpredictable
perturbations of bus voltage during early phase of
recharge . . . and know this is not very good for
the battery's service life. Putting a regulated, 10A
charger on it for an hour or so is much preferred.
