Stabilator Trim Motor
Goto page 1, 2  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
skyking76t(at)verizon.net
PostPosted: Fri Jun 16, 2017 1:41 pm    Post subject: Stabilator Trim Motor Reply with quote
Hey Everyone,
There had been some previous discussions with regards to the tail not trimming or sticking. I've had this problem since I bought my plane. Initially it was maybe once a year but over the last 7 years it has gotten to be more frequent. I recommended (tried) spraying electronics cleaner down the side of the flaps buttons. After opening the flap box it is obvious that is useless. I looked at the flap switches in the left wing. Nothing there. Tried changing out the front flap box. No joy. Tried putting the flaps down with the rear cockpit flap box and the same as the front.....lowers flaps and that was it.
I flew this past weekend and the tail trimmed to 30 degrees and stayed there. Glad it stuck in the landing configuration!
I removed the trim motor and took it to a servo/electric motor repair shop. When hooked to a power source and after we figured out the correct pins, we applied power..... nothing but a slight grinding sound and the motor got hot after only a few seconds. Armature never turned with power but free wheeled without power. To make a long story short, the armature roller bearings were worn out and when power was applied, the armature cocked and made contact with one of the field coils. We found this when we applied power and pushed on one end of the armature aft of the brushes and it started spinning. Looking at the front bearing you could see the roller balls barely moving and the play. The grease was old and dried out and probably caused the bearing failure. The tech is 99% sure the bearings are the problem. Brushes were like new and armature looked great.
So, if you guys who are experiencing a stabilator trim or not moving when it should or sticking, you may want to remove the motor and have it looked at. The Tech also checked the 4 microswitches in the square box that's attached to the motor assy and they were good. These switches tell the tail where to stop.....0, 15, and 30 degree positions.
Tony
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Dawg
PostPosted: Fri Jun 16, 2017 2:16 pm    Post subject: Stabilator Trim Motor Reply with quote
did he fix it?
On Jun 16, 2017, at 15:35, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
Hey Everyone,
Tony
Dawg
Postal
PostPosted: Fri Jun 16, 2017 11:22 pm    Post subject: Stabilator Trim Motor Reply with quote
Do you have any good pictures? This could be a good small comment to put in the next Red Alert. Deadline is the end of this month for submissions.
Feel free to send me a PM.
Postal
RPA President
FlyingHartley(at)gmail.com
PostPosted: Sat Jun 17, 2017 5:53 am    Post subject: Stabilator Trim Motor Reply with quote
The tech still has the trim motor assy as he has to get the old bearings out of the housing and order new bearings (metric you know) and lubricate everything with new grease. We spent about 4 hours just to troubleshoot. The motor has an ingenious electromagnetic brake inside so when power is interrupted, the motor/jackscrew rotation stops and it is held in place. Interestingly, before we separated the motor from the jack screw housing, turning the armature by hand would not retract or extend the jack screw but turning the adapter on the jack screw housing did extend and retract the jack screw. So it's pretty much narrowed it down to the motor itself. Being that the motor would not run initially when power was applied and took some unusual effort to get it started, confidence is high the bearings are the issue. Checking the field coils with a meter showed good. Brushes were like new. Also, being that the trim motor worked initially for departure but nothing from there on, pretty much pointed to the trim motor. I had cycled several times on the ground and got the trim moving light so the aircraft system seems to be good.
We didn't take any photos at that time cause we didn't know what we were looking for but I will ask if he can when he puts back together. Basically, separate the motor from the jack screw housing. Gently pull apart and you will see the electrobrake. In the end of the motor there is an insert that couples the motor to the brake. Remove it by pulling straight out to see the front bearing. When we got the motor running, not at full rpm, you could see the ball bearings and some were turning at a different speed or not at all and you could see the armature just barely wobbling. There's only about 0.020" clearance between the armature and field coils. You could hearing the grinding of the bad bearings or possibly the armature hitting and feel the vibration in the motor itself. The grease being 20+ years old and having no lubricity left, more than likely caused the bearings to fail and when power was applied, allowed the armature to cock just enough to be out of alignment with the field coil.
This is our theory but it seems to be validated by what we did but will know more once we get the new bearings installed. I will post more later once we get the new bearings installed, test the motor on the bench, and test in the plane.
Tony
On Saturday, June 17, 2017 3:24 AM, Hartley Postlethwaite <hap1995(at)yahoo.com> wrote:
--> L29-List message posted by: Hartley Postlethwaite <hap1995(at)yahoo.com (hap1995(at)yahoo.com)>
Postal
RPA President
FlyingHartley(at)gmail.com (FlyingHartley(at)gmail.com)
http://www.matronics.com/Navigsp; - MATRONICS WEB FORUMS -
http://forum - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
http://www.matronics.com/c
jetblast1(at)me.com
PostPosted: Sat Jun 17, 2017 9:18 am    Post subject: Stabilator Trim Motor Reply with quote
If it works he is our new trim motor guy.
john cabrera
On Jun 17, 2017, at 6:48 AM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
Tony
On Saturday, June 17, 2017 3:24 AM, Hartley Postlethwaite <hap1995(at)yahoo.com (hap1995(at)yahoo.com)> wrote:
Postal
RPA President
http://forum - NEW MATRONICS LIST WIKI -http://wiki.matronics.com
PostPosted: Sat Jun 17, 2017 1:21 pm    Post subject: Stabilator Trim Motor Reply with quote
I told him he might be going into a new business because trim motors seem to be a common problem with the L29
On Saturday, June 17, 2017 1:20 PM, John Cabrera <jetblast1(at)me.com> wrote:
john cabrera
Tony
Postal
RPA President
Dawg
PostPosted: Sat Jun 17, 2017 3:51 pm    Post subject: Stabilator Trim Motor Reply with quote
We don’t care how he did it. Just tell him to remember and make sure you keep his contact info for us to ship ours.
Bill
On Jun 17, 2017, at 15:14, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Saturday, June 17, 2017 1:20 PM, John Cabrera <jetblast1(at)me.com (jetblast1(at)me.com)> wrote:
john cabrera
Tony
Postal
RPA President
Dawg
PostPosted: Sun Jun 18, 2017 8:45 pm    Post subject: Stabilator Trim Motor Reply with quote
I would guess there are some intelligent people out there who maybe would like to know what may be causing their trim motor problem. If you don't want to know, then don't read it! Contribute something constructive instead of sarcasm.
Hey, maybe I'll trade the trim motor repair info for a few flares.....people in glass houses shouldn't throw stones.
On Sunday, June 18, 2017 9:19 AM, Anthony Royal <skyking76t(at)verizon.net> wrote:
Play nice or I'll go home with my trim motor
On Saturday, June 17, 2017 7:53 PM, William Geipel <l129bs(at)gmail.com> wrote:
Bill
john cabrera
Tony
Postal
RPA President
PostPosted: Sun Jun 18, 2017 10:55 pm    Post subject: Stabilator Trim Motor Reply with quote
Bill
john cabrera
Tony
Postal
RPA President
Dawg
PostPosted: Mon Jun 19, 2017 4:13 am    Post subject: Stabilator Trim Motor Reply with quote
Mine was a joke, but, we really want to know where to send it.
to quote the Pres. sad!
On Jun 18, 2017, at 09:06, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Sunday, June 18, 2017 9:19 AM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Saturday, June 17, 2017 7:53 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
Bill
john cabrera
Tony
Postal
RPA President
Dawg
PostPosted: Mon Jun 19, 2017 6:07 am    Post subject: Stabilator Trim Motor Reply with quote
Sorry, it didn't come across like that but that happens with emails. My apologies.
I will post shortly. He's having to find the bearings. The bearings are magneto bearings and his normal supplier won't sell to him because it's for an aircraft. He's going to another source.
On Monday, June 19, 2017 8:16 AM, William Geipel <l129bs(at)gmail.com> wrote:
Bill
john cabrera
Tony
Postal
RPA President
PostPosted: Thu Jun 22, 2017 8:12 am    Post subject: Stabilator Trim Motor Reply with quote
Ok Bill and to all you L29 owners that have had some trouble with your tail trim motor not working at times. Excuse the long narrative but I think it is important to understand what may be going on with our motors and may save time looking and troubleshooting everything but the motor.
I just picked up my tail trim motor and what he found might be a common problem with these motors. First, the bearings were shot. They are magneto bearings and they don't make them anymore. So, he doesn't know how long he will be able to get them. Down the road they may have to convert to a standard sealed roller bearing. He only uses top of the ling bearings.....SKF, FAG, etc.
Secondly, where the wiring harness goes just inside the motor, he found a wire that had the two ends butted together, as opposed to lapping over each other and cold soldered. Definitely not an acceptable splice/connection in any application. He said there had been arching between the wires for a very long time and they finally burnt apart. He thinks this is what caused the trim motor to be intermittent and finally fail, along with worn out bearings. The safety wire with the red seals on the motor was still intact so the wiring problem looks to be a manufacturing issue.
After the new bearings (and they are not cheap) and fixing the wire, the motor runs perfectly, quiet, and drives the jack screw now as it should.
After talking with the owner, he has agreed to look at your trim motors and see if they can be fixed. He does not work on the jack screw assy, only the trim motor, but send the complete assy. The only stipulation is you will need to sign a liability release, releasing him and the business from ANY and ALL liability associated with the repair of the electric motor before he does any work. I had to sign a release when I picked up my motor. The gentleman is very knowledgeable, thorough, and honest.
So, here is the contact info:
Owner's name is Mike Loving
Blue Ridge Servo Motor Repair, LLC
1017 Tennessee St.
Salem, Virginia 24153
Phone: 540-375-2990
email: blueridgeservomotor(at)gmail.com
Hope this helps.
Tony
On Monday, June 19, 2017 10:09 AM, Anthony Royal <skyking76t(at)verizon.net> wrote:
Bill
john cabrera
Tony
Postal
RPA President
Dawg
PostPosted: Thu Jun 22, 2017 8:19 am    Post subject: Stabilator Trim Motor Reply with quote
how much was it?should we order the bearings to have them I stock while he can still find them?
On Jun 22, 2017 10:13 AM, "Anthony Royal" <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
1017 Tennessee St.
Phone: [url=tel:(540)%20375-2990]540-375-2990[/url]
email: blueridgeservomotor(at)gmail.com (blueridgeservomotor(at)gmail.com)
Hope this helps.
Tony
On Monday, June 19, 2017 10:09 AM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Monday, June 19, 2017 8:16 AM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
Bill
On Saturday, June 17, 2015994120586602274473yiv8510581628" href="mailto:jetblast1(at)me.com" target="_blank">jetblast1(at)me.com> wrote:
john cabrera
Tony
Postal
RPA President
Dawg
PostPosted: Thu Jun 22, 2017 12:34 pm    Post subject: Stabilator Trim Motor Reply with quote
My bill was just under $400. There were several hours of trouble shooting time. With the electromomagnetic brake inside it's a little more complicated than a standard motor, plus the bearings and shipping cost to get the bearings so I could pick up today today, plus the wiring repair. He's going on vacation tomorrow till the 8th and I'm leaving for South America tomorrow. I guess each bill will vary.
May not be a bad idea to have the bearings on hand. They would have to be prepaid for though. I don't have the part numbers myself. Would have to call the owner.
On Thursday, June 22, 2017 12:22 PM, Bill Geipel <l129bs(at)gmail.com> wrote:
1017 Tennessee St.
Phone: [url=]540-375-2990[/url]
Hope this helps.
Tony
Mine was a joke, but, we really want to know where to send it.to quote the Pres. sad!
Bill
john cabrera
Tony
Postal
http://www.matronics.com/ Navigsp; - MATRONICS WEB FORUMS -
Dawg
PostPosted: Thu Jun 22, 2017 7:03 pm    Post subject: Stabilator Trim Motor Reply with quote
A replacement would cost more so not a bad deal.Find out how much for the bearings and I would like to order a set.
On Jun 22, 2017, at 14:33, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Thursday, June 22, 2017 12:22 PM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
1017 Tennessee St.
Hope this helps.
Tony
Bill
On Saturday, June 17, 2015994120586602274473yiv8510581628" href="mailto:jetblast1(at)me.com (jetblast1(at)me.com)" target="_blank">jetblast1(at)me.com (jetblast1(at)me.com)> wrote:
john cabrera
Tony
Postal
Dawg
PostPosted: Thu Jun 22, 2017 7:54 pm    Post subject: Stabilator Trim Motor Reply with quote
Will do.
Tony
On Thursday, June 22, 2017 11:05 PM, William Geipel <l129bs(at)gmail.com> wrote:
1017 Tennessee St.Salem, Virginia 24153
Hope this helps.
Tony
Bill
john cabrera
Tony
Postal
PostPosted: Fri Jun 30, 2017 5:30 pm    Post subject: Stabilator Trim Motor Reply with quote
Bearings for the trim motor are $70 + tax + shipping end user cost. If anyone wants any, let me know and I'll hook you up with the contact
On Thursday, June 22, 2017 11:50 PM, Anthony Royal <skyking76t(at)verizon.net> wrote:
Will do.
Tony
1017 Tennessee St.
Hope this helps.
Tony
Bill
john cabrera
Tony
Postal
jetblast1(at)me.com
PostPosted: Fri Jun 30, 2017 9:16 pm    Post subject: Stabilator Trim Motor Reply with quote
Ok,
Please send me the contact info for the bearings at jetblast1(at)me.com (jetblast1(at)me.com)
Thank you
John Cabrera
On Jun 30, 2017, at 6:26 PM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Thursday, June 22, 2017 11:50 PM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
Will do.
Tony
On Thursday, June 22, 2017 11:05 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
1017 Tennessee St.
Hope this helps.
Tony
Bill
john cabrera
Tony
Postal
Dawg
PostPosted: Sat Jul 01, 2017 4:20 pm    Post subject: Stabilator Trim Motor Reply with quote
Me too.
On Jun 30, 2017, at 23:16, John Cabrera <jetblast1(at)me.com (jetblast1(at)me.com)> wrote:
Ok,
Thank you
John Cabrera
Will do.
Tony
1017 Tennessee St.
Hope this helps.
Tony
Bill
john cabrera
Tony
Postal
Dawg
Alekh
PostPosted: Thu Oct 26, 2017 12:53 pm    Post subject: Re: Stabilator Trim Motor Reply with quote
Hmm…..it seems to me you did spend at least $800US + time consuming. Why not for that kind of money just buy a new surplus factory sealed trim motor? Slide in replacement. And no need to sign a liability release.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
