Posted: Tue Jun 20, 2017 6:46 pm Post subject: Tosten grip wiring with car-relay for trim |
At 10:01 AM 6/20/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Achille" <mickael.t(at)live.fr>
Hello,
I want to wire my new grip tosten with my basic 12v electrical actuating as trim (up/down) pulling a spring.
I bought a double car relay to do some test to find the good wiring diagram but before that I prefer asking in this forum how can I wire it if anybody know the response ?
Before I was a double pole switch, wire by the previous owner.
I had a problem with the previous wiring, when i actuated my trim, my compas begin to turn completely. The motor/switch were not close to the compas.
I have tested to set the motor very close to the compas to do a test. Without all the wire juste motor and a small battery. And in this case it don't turn ! I don't understand why. |
It's difficult to diagnose the underlying
physics for your observations without first-
hand observation and diagnosis. I can tell
you that incidences of wiring
interfering with the compass is rare.
Suggest you get the new trim system installed
using the drawing cited below as guidance.
Then see if the compass is still getting
trashed . . . it will be easier to figure
out why it IS having problems than to
figure out why it is NOT having problems.
| Quote: | | I find this documentation to do my wire. |
I think this wiring diagram is what you're
needing.
http://tinyurl.com/y7mwhg4t
Achille
Posted: Fri Jun 23, 2017 4:26 am Post subject: Re: Tosten grip wiring with car-relay for trim |
Thank you bob,
I haven't see the response before and I answered in other topic.
I will try it and I will come back to tell if it run better or not. (if it run well also to tell what it was bad if it can help anyone.)
I find relay a bit slow for the motor trim operation, we haven't another solution to wire it with another system ? (transistor ? I don't know well what is it, I just read that on internet)
Thank you !
Mickaƫl
