Does Anyone Recognize This AMP 12 Pin Connector?
PostPosted: Wed Jun 21, 2017 10:05 am    Post subject: Does Anyone Recognize This AMP 12 Pin Connector? Reply with quote
At 12:02 PM 6/21/2017, you wrote:
Hi All,
I need to rearrange the wires on this AMP 12 pin connector and my hope is to simply pop out the terminal ends and leave the wires still connected and just move them to the proper pin locations and pop them back in (I might have to re-bend the metal retainer tabs).
The questions are:
Does anyone know what terminal connector this is?
How does one (me) unseat the terminal ends from the connector and what tool should be used?\
What does the other end look like?
TE Connectivity (AMP) offers a series of
mate_n_lock connectors which all use
the same pins
If you look over this array of pins
http://tinyurl.com/y8r989bn
you will find that the 'business end'
of pins and sockets are uniform while
the wire ends are available in a range
of sizes. I believe they all extract
with the same tool.
It would really help to see the other
side of the connector.
PostPosted: Wed Jun 21, 2017 10:16 am    Post subject: Does Anyone Recognize This AMP 12 Pin Connector? Reply with quote
I 'think' this is the tool you'll need
or one very similar. exact p/n to be
determined.
