Kx 170 b radio, ki211c indicator no power to ki 211c pin
PostPosted: Sun Jun 25, 2017 12:44 pm    Post subject: Kx 170 b radio, ki211c indicator no power to ki 211c pin Reply with quote
At 11:16 AM 6/25/2017, you wrote:
Thanks Bob, that is where I was heading. But it seems odd that the wire pins to tray buzz on the ohmeter. Must be doing something wrong.  Â
Connectors captive to a slide-in tray can be problematic.
You may be wrestling with a pin engagement issue . . . and
if one path is coming up short, then there may be more.
