[Non-DoD Source] Another Air Problem
mark.bitterlich(at)navy.m
PostPosted: Thu Jun 29, 2017 8:11 am    Post subject: [Non-DoD Source] Another Air Problem Reply with quote
After you reset the toggle valves on each gear (as several others have mentioned), put the aircraft on jacks and test it there. You will hear any leaks, and be able to carefully observe proper operation. If you are having problems with the landing gear, the place to check the problem is not in flight.
Mark
