jgamtmann2(at)gmail.com Guest
Posted: Mon Jul 10, 2017 9:33 am Post subject: AeroElectric-List Digest: 17 Msgs - 07/09/17 |
I got a gazillion pages of gibberish. Jürgen
On Mon, Jul 10, 2017 at 1:00 AM, AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)> wrote:
Quote: | *
Today's complete AeroElectric-List Digest can also be found in either of the
of the AeroElectric-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-07-09&Archive=AeroElectric
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-07-09&Archive=AeroElectric
AeroElectric-List Digest Archive
Total Messages Posted Sun 07/09/17: 17
Today's Message Index:
1. 01:05 AM - Re: Re: IVO Prop current limiter (Eric Page)
2. 07:01 AM - Re: IVO Prop current limiter (kfav8r)
3. 07:59 AM - Re: Re: IVO Prop current limiter (Paul A. Fisher)
4. 09:07 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, III)
5. 09:19 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, III)
6. 09:26 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, III)
7. 03:55 PM - Fat wires (GTH)
8. 04:22 PM - Re: Fat wires (Alec Myers)
9. 04:39 PM - Re: Fat wires (Robert L. Nuckolls, III)
10. 04:40 PM - Re: Fat wires (rayj)
11. 04:47 PM - Re: Fat wires (user9253)
12. 04:50 PM - Re: Fat wires (Charlie England)
13. 06:43 PM - Re: Re: IVO Prop current limiter (Paul A. Fisher)
14. 07:07 PM - Re: IVO Prop current limiter (Eric Page)
15. 08:12 PM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, III)
16. 08:35 PM - Re: IVO Prop current limiter (Eric Page)
17. 08:59 PM - Re: IVO Prop current limiter (Eric Page)
________________________________ Message 1 _____________________________________
Time: 01:05:54 AM PST US
From: Eric Page <edpav8r(at)yahoo.com (edpav8r(at)yahoo.com)>
Subject: Re: Re: IVO Prop current limiter
I've converted Bob's sketches to a CAD file. =C2-Anyone with interest in
the project please look over my work (see attached PDF) and post any change
s/critiques for the group to consider. =C2-When we're all happy, I'll tur
n it into a printed circuit board, stuff it with parts and a DIP-8 socket,
and send it to Paul so he can add a programmed PIC to test with his code.
A couple of notes:- I've assumed that the DPDT motor-control relay will be
mounted elsewhere (off the PCB).- I've drawn a notional wiring diagram incl
uding a switch and a second relay. =C2-If this isn't how the IVO prop wor
ks, let me know what to change.- I guessed at the correct PIC GPIO pins to
use. =C2-Paul, let me know if you need something different.
Things to consider:- For BOM simplicity, I used the same 2k resistors for R
1-R8, and 0.1uF for C2 and C3. =C2-Any problems with this?- Any other com
ponent substitutions or value changes?
- What's the desired physical envelope (PCB with mounting holes / PCB for a
small potting box / something else...)?- What type of connector(s) should
be used (a DB-9 is shown)?- Are the fuse values on the wiring diagram appro
priate?- What AWG should be specified for each wire run?
Doug (kfav8r), in order to give you credit on the schematic, would you like
to send me your last name?
Eric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rvtach
Posted: Tue Jul 11, 2017 4:55 am Post subject: Re: AeroElectric-List Digest: 17 Msgs - 07/09/17 |
FYI: Everyone who reads the list via email just got a gazillion pages of gibberish due to your post. This is an extra PIA for those of us who subscribe to the digest as we have to scroll through all of the gibberish you posted to get to something that matters. Thanks for sharing.
_________________ Jim McChesney
Tucson, AZ
RV-7A Finishing Kit |
ceengland7(at)gmail.com Guest
Posted: Tue Jul 11, 2017 5:28 am Post subject: AeroElectric-List Digest: 17 Msgs - 07/09/17 |
On Tue, Jul 11, 2017 at 7:55 AM, rvtach <rvtach(at)msn.com (rvtach(at)msn.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "rvtach" <rvtach(at)msn.com (rvtach(at)msn.com)>
Jim McChesney
Tucson, AZ
RV-7A Finishing Kit
Jim,
I get the list via email (*not* digest; is that how you actually get it?), and I have no idea what you're talking about, or who you're talking to.
You might need to be a bit more specific.
Charlie
rvtach
Posted: Tue Jul 11, 2017 8:50 am Post subject: Re: AeroElectric-List Digest: 17 Msgs - 07/09/17 |
Hi Charlie- I apologize for not being clear. I was directing my comment to Jurgen - the poster who complained about a gazillion pages of gibberish and in so doing included the gazillion pages of gibberish for the rest of us to experience.
I get the list via the once daily digest. When someone replies to a digest email, the entire content of the that 24 hours of email are included in that reply. And then when the list subscribers get their next digest email they have to scroll through an entire 24 hours of list postings in the middle of the current digest of emails. Jurgens post includes an example of how the digest version of the list arrives in subscribers' mail box.
Regards-
Jim
Tucson, AZ
