gilles.thesee(at)free.fr Guest
Posted: Sun Jul 09, 2017 2:55 pm Post subject: Fat wires |
Hi all,
Some buddies asked me to install the wiring in their brand new project.
The engine is a Rotax with short connexions so the fattest wires in the
ship will be AWG 6.
Due to restricted space, they installed their fuseblock on a hinge
within inches from the battery contactor, but the gauge 6 wire from the
contactor to the bus proves very stiff and hard to manage with this
pivoting installation.
I considered using a short length of welder cable, but the insulation is
so thick that it did not help much.
What would be your opinion about downsizing this particular wire to AWG
8 or 10 for more flexibility ?
Thanks in advance,
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
alec(at)alecmyers.com Guest
Posted: Sun Jul 09, 2017 3:22 pm Post subject: Fat wires |
what about using a short stub of 8 gauge with a good splice to 6 gauge?
On Jul 9, 2017, at 18:54, GTH <gilles.thesee(at)free.fr> wrote:
Hi all,
The engine is a Rotax with short connexions so the fattest wires in the ship will be AWG 6.
Due to restricted space, they installed their fuseblock on a hinge within inches from the battery contactor, but the gauge 6 wire from the contactor to the bus proves very stiff and hard to manage with this pivoting installation.
I considered using a short length of welder cable, but the insulation is so thick that it did not help much.
What would be your opinion about downsizing this particular wire to AWG 8 or 10 for more flexibility ?
Thanks in advance,
Best regards,
Gilles
Posted: Sun Jul 09, 2017 3:39 pm Post subject: Fat wires |
At 05:54 PM 7/9/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: GTH <gilles.thesee(at)free.fr>
Hi all,
Wires need to be sized for the expected service.
Fat wires in the starter circuit will, no doubt,
want to be 6AWG. Given that the bus loads on this
aircraft cannot exceed the system loads. The
bus feeder can be downsized. What size alternator
is installed? Bus loads generally don't exceed
alternator output . . . 12AWG would be fine for
up to 30A of engine driven power source.
I would use a fusible link on such smaller bus
feeders . . . a 6" piece of 16AWG under
some firesleeve would be about right for 12AWG
bus feeder.
raymondj(at)frontiernet.n Guest
Posted: Sun Jul 09, 2017 3:40 pm Post subject: Fat wires |
Maybe a couple of extra coils in the wire would solve the flexibility
problem.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 07/09/2017 05:54 PM, GTH wrote:
Hi all,
ship will be AWG 6.
Thanks in advance,
Joined: 28 Mar 2008 Posts: 1975 Location: Riley TWP Michigan
Posted: Sun Jul 09, 2017 3:47 pm Post subject: Re: Fat wires |
My Rotax 912 powered RV-12, along with 500 others that are flying, all have 12 AWG wires about 4 feet long connecting the Dynamo and battery to the main power bus. The starter is connected with 8 AWG about 2 feet total length.
_________________ Joe Gores |
ceengland7(at)gmail.com Guest
Posted: Sun Jul 09, 2017 3:50 pm Post subject: Fat wires |
On 7/9/2017 5:54 PM, GTH wrote:
Hi all,
Thanks in advance,
You didn't mention the actual load, but if the plane is Rotax powered,
I'd guess that it shouldn't be too large.
I did a quick google search for a DC current capacity calculator, &
found this:
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
If you plug in 30 amps, 1% voltage loss, & 0.2 meters length (~8"), It
says that 14 AWG is adequate. 70 amps asks for 10 AWG. Remember, with
less than a foot of wire, there's very little resistance loss unless the
wire is grossly undersized.
6 AWG sounds like major overkill to me, unless they're trying to run the
starter current through it.
Posted: Mon Jul 10, 2017 10:01 am Post subject: Fat wires |
| Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com> (ceengland7(at)gmail.com)
You didn't mention the actual load, but if the plane is Rotax powered, I'd guess that it shouldn't be too large.
6 AWG sounds like major overkill to me, unless they're trying to run the starter current through it. |
Charlie, Joe, Bob, Raymond, Alec,
Thank you for responding.
Indeed the Rotax 912iS alternator is rated at 30 A, so 12 AWG with a 16 AWG fuselink seems adequate, and the wire stiffness problem will be solved.
Thanks a lot,
Best regards,
Gilles
