Ford model A engine part
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
flyingbrick
PostPosted: Tue Jul 11, 2017 7:08 am    Post subject: Ford model A engine part Reply with quote
On my Model A there is a strange bulb on the front cover plate which seems to have no purpose. It can be seen in the attached picture. Does anybody know what this is for?
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Taken from West Coast Piet site
 Filesize:  65.15 KB
 Viewed:  1833 Time(s)
tkreiner
PostPosted: Tue Jul 11, 2017 7:56 am    Post subject: Re: Ford model A engine part Reply with quote
Are you describing the item in this attached pic?
If so, it's the original timing pin for the engine. Remove it, reverse it in the hole, and rotate the engine to TDC... When at TDC, the pin will slip deeper int the cover, as it engages a hole in the cam.
Be SURE to remove and tighten.
 Filesize:  27.38 KB
 Viewed:  1822 Time(s)
Tom Kreiner
fastnaught(at)windstream.
PostPosted: Tue Jul 11, 2017 8:03 am    Post subject: Ford model A engine part Reply with quote
That small protrusion contains the timing pin
http://forums.matronics.com/viewtopic.php?p=470893#470893
http://forums.matronics.com//files/bulb_model_a_179.jpg
flyingbrick
PostPosted: Tue Jul 11, 2017 8:03 am    Post subject: Re: Ford model A engine part Reply with quote
Thanks!
flyingbrick
PostPosted: Tue Jul 11, 2017 8:06 am    Post subject: Ford model A engine part Reply with quote
Thank you!
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
