Alternator
kearney
PostPosted: Mon Jul 17, 2017 5:47 am    Post subject: Alternator Reply with quote
Hi
I am looking at the Van's FWF kit and am wondering about the supplied alternator. Does anyone know the make / model of the alternator.
My plan is to use an alternator that is easily replaced so that a failure doesn't mean a long delay on the ground.
Cheers
Les
C-GCWZ Flying
C-GROK Some assembly required
Wedig435
PostPosted: Mon Jul 17, 2017 8:33 am    Post subject: Alternator Reply with quote
Use a 1 wire GM alternator
About $60 at auto zone lifetime warrantee
Jim Villani
Broker / Salesman
Great Real Estate
Jim(at)Sold702.com
Mammoth Creek Excavation
WeDig435.com
702 379 5524 cell
-------- Original message --------
Date: 07/17/2017 7:54 AM (GMT-07:00)
Subject: Alternator
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca>
Hi
Cheers
Les
C-GCWZ Flying
http://forums.matronics.com/viewtopic.php?p=471103#471103
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
matronics.com
p;   -Matt Dralle, List Admin.
Jim V
Bob Turner
PostPosted: Mon Jul 17, 2017 10:48 am    Post subject: Re: Alternator Reply with quote
The alternator supplied with the FWF kit in 2010 was a Plane Power 60 amp unit with an internal regulator.
I don't know if that has changed or not since then.
Bob Turner
RV-10 QB
Kelly McMullen
PostPosted: Mon Jul 17, 2017 12:29 pm    Post subject: Alternator Reply with quote
Hmm, when I ordered in early 2010 it was still shown as Nippondenso, so I deleted and bought Plane Power on my own.
-sent from the I-droid implanted in my forearm
On Mon, Jul 17, 2017 at 11:48 AM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=471111#471111
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
unitink72(at)gmail.com
PostPosted: Tue Jul 18, 2017 7:27 am    Post subject: Alternator Reply with quote
I've done a lot of research on the subject.  The best option I've found is the Autozone 14118 from a 1976 Chevy Luv.  60 Amp, turns the right way, and externally regulated.  I'm not sure why its not more popular unless there's something I'm missing.
-Josh
On Mon, Jul 17, 2017 at 8:47 AM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
C-GCWZ Flying
WIKI -
Lenny Iszak
PostPosted: Tue Jul 18, 2017 8:32 am    Post subject: Re: Alternator Reply with quote
Just want to mention this so it doesn't get overlooked in the enthusiasm of getting a more easily replaceable alternator.
If you are using an automotive alternator make sure you add overvoltage protection to your charging system. B & C has a crowbar module or there's a more modern option from Perihelion Designs. If you don't have one of these and your voltage regulator fails it can kill a bunch of your expensive avionics.
Couple that with a lithium battery that has OV protection built in, in an overvoltage situation it disconnects itself from the circuit, there's nothing to absorb the high voltage and then all of your avionics are done before you even think about hitting your master switch.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
kearney
PostPosted: Thu Jul 20, 2017 2:37 pm    Post subject: Re: Alternator Reply with quote
Lenny
I agree on the OV protection. If you are using a VP-X, it will kill the field in an OV situation.
Cheers
Les
C-GCWZ Flying
LarryRosen
PostPosted: Mon Jul 24, 2017 5:16 pm    Post subject: Re: Alternator Reply with quote
Josh, Where did you get the mounting hardware for the LUV alternator. Did the Van's BRACKET KIT FOR GENERIC NIPPON DENSO ALT work?
-Josh
Larry Rosen
#40356
N205EN (reserved)
<http>
