		flyboy(at)gmail.com Guest
				 Posted: Tue Jul 04, 2017 2:16 pm    Post subject: F-1046 Longeron to F-1005E Gusset Holes |
				I lined up the F-1046L longeron with the gusset as described on page 29-9, with the longeron flush with the skin. Then, I drilled the holes. The edge distance is terrible, but I can't see what I did wrong. I've searched and found others with the same problem, but no resolutions turn up. The diagram on 29-9 sure acts like these holes will wind up in the middle of the longeron, but I don't see how.
 Waiting to drill the other side until I can figure out how to avoid the same problem. Looks to me like I should replace the longeron, but I don't know how to do it any differently and still have the longeron flush with the skin.
 https://goo.gl/photos/J8s8gheQ1GBmUUi1A
 https://goo.gl/photos/z11vaX6PZt3Zc1w69
 Any suggestions?
		philperry9
				 Posted: Tue Jul 04, 2017 6:26 pm    Post subject: F-1046 Longeron to F-1005E Gusset Holes |
				I don't think you need to rebuild the longeron.   Give Vans a call tomorrow and send them the photos too.   I believe they have developed a repair for this.    IIRC, it involves a gusset.   But give them a shout and I'm pretty sure they'll be able to take care of you.
 At least you noticed it now.   Some folks have built on and had to correct it later after the tail is assembled.  Only to have to tear it back apart to fix it.
 On Jul 4, 2017, at 4:16 PM, Berck E. Nash <flyboy(at)gmail.com (flyboy(at)gmail.com)> wrote:
  	  | Quote: | 	 		  I lined up the F-1046L longeron with the gusset as described on page 29-9, with the longeron flush with the skin. Then, I drilled the holes. The edge distance is terrible, but I can't see what I did wrong. I've searched and found others with the same problem, but no resolutions turn up. The diagram on 29-9 sure acts like these holes will wind up in the middle of the longeron, but I don't see how.
 Any suggestions?
				 Posted: Wed Jul 05, 2017 10:05 am    Post subject: F-1046 Longeron to F-1005E Gusset Holes |
				Thanks, I've got an e-mail out to them with the photos, I'll let you know what they send back.
 Rebuilding the longeron isn't a big deal.  Heck, I can probably bend this one in under half an hour after all the practice with the first four.  The bigger deal is that after I build it, I'm not sure what to do to fix the problem.  I can line the longeron up so that the holes in the gusset are in the middle, but that's going to create quite a gap to the skins.  It looks like a similar situation on the other side.
 On Tue, Jul 4, 2017 at 8:25 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
  	  | Quote: | 	 		  I don't think you need to rebuild the longeron.   Give Vans a call tomorrow and send them the photos too.   I believe they have developed a repair for this.    IIRC, it involves a gusset.   But give them a shout and I'm pretty sure they'll be able to take care of you.
 Any suggestions?
		kearney
				 Posted: Sat Jul 08, 2017 3:35 pm    Post subject: Re: F-1046 Longeron to F-1005E Gusset Holes |
				Hi
 I was reading this thread with some interest as I was about to do this step as well.
 Prior to drilling I marked where the holes would be using a sharpie through the gusset holes. The edge distance was not good for the aft most holes.
 The source of the problem was that the flange of the gusset was not parallel to the skin / longeron.
 I was think of using a shim to move the longeron inboard but then realized there was a much simpler solution.
 If you rotate the F-1005C you can get the gusset flange to line up parallel to the skin. This will give good edge distance. You will need to rotate the F1005 beyond where you want it a sit will spring back a little.
 Cheers
 Les
 C-GCWZ Flying
 C-GROK some assembly required
				 Posted: Sun Jul 09, 2017 5:48 pm    Post subject: F-1046 Longeron to F-1005E Gusset Holes |
				Thanks, I eventually came to the same conclusion.  Vans wrote back and said they didn't know what caused the problem, but that I could just add a doubler.  That didn't seem like a reasonable solution to me. Sure, I could add a doubler and put new holes in the longeron, but the new holes through the doubler would have bad edge distance in the gusset.  I could add more holes way out in the gusset, but this wasn't satisfying to me, either.
 After spending a lot of time playing with the parts and a sharpie, I realized what you did, that I could pivot the gusset outboard and fix the edge distance.  For the right side (which I hadn't drilled yet), I went ahead and drilled through the side skin in the forward-most hole into the longeron so I could cleco to the skin and be sure that alignment was correct.  Then, I simply squeezed the gusset inboard with my hands and drilled the aft-most hole first.  Put a cleco in it, and drilled the rest.  I think they came out just fine.
 So, I rebuilt the left longeron with the bad holes (probably took me about the same amount of time as making a doubler from scratch, figuring out rivet lengths, etc, would have taken).  Drilled the new longeron with my new technique and I think it too is now fine.
 https://goo.gl/photos/t63mDsvT4a5nmDFu5
 https://goo.gl/photos/bgZw1QuKYaSiWZLS8
 So, a note to anyone else who hasn't yet done this: check your edge distance before drilling these holes (particularly on the aft-most hole), and note that you can pull the gusset outboard as necessary to get the right edge distance.
 On Sat, Jul 8, 2017 at 5:35 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
  	  | Quote: | 	 		  --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
  Hi
  Cheers
  Les
  C-GCWZ Flying
  http://forums.matronics.com/viewtopic.php?p=470800#470800
   FORUMS -
  WIKI -
  b Site -
            -Matt Dralle, List Admin.
				 Posted: Thu Jul 20, 2017 2:09 pm    Post subject: F-1046 Longeron to F-1005E Gusset Holes |
				On 7/4/2017 6:16 PM, Berck E. Nash wrote:
 On related note; I would recommend that builders apply corrosion
 protection (primer, alodine) to the longeron, particularly  where it
 joins to the skin.
 Vans is very conservative with specifying areas where they recommend
 priming and I don't recall if this is one of those areas.  Many builders
 are obsessive about priming and will certainly prime/alodine it.  I
 missed this one and had to take some action to stop some filiform
 corrosion developing at that joint.
 Bill "in no way, shape or form is trying to restart any version of the
 primer wars" Watson
  Any suggestions?
				 Posted: Thu Jul 20, 2017 6:58 pm    Post subject: F-1046 Longeron to F-1005E Gusset Holes |
				Thanks, good call. Vans does specifically call out priming the longerons.  First, in section 5, they specifically say to prime all angle, as it's not alclad.  Then, in section 29, it specifically says to prime the longerons, then other parts as desired.
 I'm not priming anything Van's doesn't say to prime, but I did miss the aluminum angle in the tail cone, so I'm going to go back and do it.
 Berck (feeling like he missed out, since he started building too late to join the primer wars)
 On Thu, Jul 20, 2017 at 4:09 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
  	  | Quote: | 	 		  --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
  On related note; I would recommend that builders apply corrosion protection (primer, alodine) to the longeron, particularly  where it joins to the skin.
  Vans is very conservative with specifying areas where they recommend priming and I don't recall if this is one of those areas.  Many builders are obsessive about priming and will certainly prime/alodine it.  I missed this one and had to take some action to stop some filiform corrosion developing at that joint.
  Bill "in no way, shape or form is trying to restart any version of the primer wars" Watson
  Any suggestions?
   FORUMS -
  WIKI -
  b Site -
