Yet another Video
lcottrell
PostPosted: Thu Jul 27, 2017 2:17 pm    Post subject: Yet another Video Reply with quote
I had thought that I was done, but then the Monsoons from NM and Arizona decide to bend the jet stream our way. This of course brings heat and moisture. The heavy clouds build up static electricity that just has to discharge as it passes over some of the most volatale terrain outside of lower California. We were under "flood watch", but the forecast was for only 30 percent of the area. Well the floods did not arrive, but the lightening did.
The area that got the most of it was the area burned over 3 or 4 years ago, and consisting of Cheat Grass. Of course fires soon generate their own wind, and it doesn't take too long before things get interesting. I waited until I was sure that the fire was out and whatever TFR's were in place, were not in effect. The fire consumed about 1700 acres before it was put out.
You will notice that at the South end of the fire, further burning was stopped by the application of Fire retardant. They use "crop dusters" first, to drop loads of retardant. It takes time and quite possibly the large tankers are in use at higher priority fires and are not available. You can see quite plainly that they effectively put out the fire on the South end of the mountain.
https://vimeo.com/227323102   password    owyheeflyer
Larry
lcottrell
PostPosted: Thu Jul 27, 2017 7:41 pm    Post subject: Yet another Video Reply with quote
I made a mistake on the size of the fire, Rather than 1700 acres correct that to 17000 acres.
Larry
gdhelton(at)gmail.com
PostPosted: Fri Jul 28, 2017 2:50 am    Post subject: Yet another Video Reply with quote
That's okay, Larry. It was another well done video. My new virb elite arrived yesterday. Now it's going be figuring out the software and where to mount it. Looks like a nice camera. George
Have a great day!
On Jul 27, 2017, at 11:40 PM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
Larry
