Backup Alternator / Backup Battery Sanity Check
PostPosted: Sun Aug 06, 2017 11:56 am    Post subject: Backup Alternator / Backup Battery Sanity Check Reply with quote
At 12:41 PM 8/6/2017, you wrote:
Folks,
Can you give me a sanity check? I am building a Bede BD-4C with an MGL EFIS. This is largely a mechanical airplane so manual trim, no gear motors, manual flaps, etc. Between the low current consumption of the EFIS and using LED lights, a backup alternator will run everything in the airplane except the pitot heater; the typical current draw is 21.57 amps and maximum is 31.49 amps. (Pitot heat adds 10 amps.)
With that in mind, I plan on including a 30 amp backup alternator and no backup battery. I figure:
  • If the engine is turning, I will certainly have one of the two alternators operable.
  • If the engine is not turning, the main battery ought to keep the electrons flowing until I reach the ground.
Am I missing anything?
Nope
