[Non-DoD Source] Re: Re: Cj6 lift off without jacks
mark.bitterlich(at)navy.m
PostPosted: Wed Aug 23, 2017 7:13 am    Post subject: [Non-DoD Source] Re: Re: Cj6 lift off without jacks Reply with quote
Very little leaves me speechless.
From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of Jan Mevis [j.mevis(at)computer.org]
Sent: Wednesday, August 23, 2017 7:26 AM
To: yak-list(at)matronics.com
Subject: [Non-DoD Source] Re: Re: Cj6 lift off without jacks
I am impressed, when looking at the pictures.
I suppose that you also calculated or estimated the structural strenghth
of the roof of your hangar?
Jan
On 23/08/2017, 08:30, "airmanv2" <owner-yak-list-server(at)matronics.com on
behalf of bruno.blanchard2(at)gmail.com> wrote:
Hello ,
Finlay we succeed to raise the Nanchang without jacks and tested the gear
without any damage to the plane:
-remove the fairing between the dihedral and horizontal fixed part of the
wing.
- you will find 4 mounting brackets with safety nuts , put a sling
(4000lbs)below the 2 upper ones to avoid to damage hoses ans wires. Do
the same for other side
- remove engine fairing and put a sling (4000lbs) bellow 2 upper bars of
he engine mount as close as possible to the engine (in front of the
generator)
- use 3 come-along chain attached to the frame of the hangar the both for
wing will have to support about 1000lbs each, the nose one will have to
support about 600lbs. check the resistance of the hangar frame is enough.
- raise slowly and silmutaneously with friends.
the plane is very stable and you can climb on it carefully.
Fly safe
http://forums.matronics.com/viewtopic.php?p=472080#472080
http://forums.matronics.com//files/img_4345_156.jpg
http://forums.matronics.com//files/img_4341_637.jpg
http://forums.matronics.com//files/img_4340_312.jpg
http://forums.matronics.com//files/img_4333_230.jpg
http://forums.matronics.com//files/img_4336_868.jpg
http://forums.matronics.com//files/img_4337_108.jpg
