Datum for KIS 2 seat?
pastormac62
PostPosted: Tue Aug 29, 2017 3:11 pm    Post subject: Datum for KIS 2 seat? Reply with quote
Hi guys,
Trying to do weight and balance on my plane. Is the datum at the firewall?
Thanks!
To our success, Stephen McIntosh
Keith.Miller(at)esa.int
PostPosted: Tue Aug 29, 2017 11:50 pm    Post subject: Datum for KIS 2 seat? Reply with quote
Stephen
Section 4 of the build manual covers the station reference points
Quote "The longitudinal locations on an aircraft are described as stations,
and the station dimensions are generally in inches as measured aft of the
reference station. Negative station locations are for those locations which
are forward of this reference point. Various builders and designers use
different techniques for establishing the reference "zero" station location.
In some cases this may be an imaginary vertical plane completely in space in
front of the aircraft. For the KIS aircraft the zero station is located at
the aft surface of the propeller spinner. A reference station at STATION 32
will be established during the fuselage assembly at the moulded in "joggle"
which provides clearance for the aft edge of the cowling. All components
added to this assembly will be located based on this station reference
plane.. The station locations will continue to be of importance after the
assembly of the aircraft is completed, particularly in weight and balance
determinations. Station locations of major components are required for
computations of weight and balance to assure safe loading of any aircraft".
Be aware that in some cases the cowlings did not fit very well ( they were
too short) and this joggle line was built up by some builders . If you
suspect this the remove the lower cowling and drill a small hole as close
to the stainless steel firewall and then the Station 32 will be 5/16"
further aft ( 1/4 for the ply firewall and 1/16 for the fibrefax and
stainless steel sheet )
Hope that helps,
To: kis-list(at)matronics.com
Date: 08/30/2017 01:11 AM
Subject: Datum for KIS 2 seat?
Sent by: owner-kis-list-server(at)matronics.com
Hi guys,
Thanks!
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
pastormac62
PostPosted: Wed Aug 30, 2017 2:38 am    Post subject: Datum for KIS 2 seat? Reply with quote
Thanks!!!
On Aug 30, 2017, at 3:48 AM, Keith.Miller(at)esa.int wrote:
Stephen
Hope that helps,
Hi guys,
Thanks!
PostPosted: Wed Aug 30, 2017 4:35 am    Post subject: Datum for KIS 2 seat? Reply with quote
I should have added that Station 0 ( aft face of the propeller spinner) ,
probably only applies if you have the original CAM 100 motor (that was
fitted to the first factory demonstrator). that's why everything should be
referenced back to Station 32 as this is a constant on every build
regardless of the motor up front .
Date: 08/30/2017 12:40 PM
Subject: Re: Datum for KIS 2 seat?
Thanks!!!
Stephen
which
location.
in
32
close
Hope that helps,
Hi guys,
Thanks!
or addressees only.
or in part) of its
sender.
pastormac62
PostPosted: Wed Aug 30, 2017 8:11 pm    Post subject: Datum for KIS 2 seat? Reply with quote
Thanks!!!
Thanks!!!
> Stephen
which
location.
in
32
close
> Hope that helps,
> From: pastormac(at)comcast.net
> Hi guys,
> Thanks!
or addressees only.
or in part) of its
sender.
