rickofudall
Posted: Thu Sep 07, 2017 11:47 am Post subject: Powerfin prop for sale |
I'm trying to clear out the hangar and I thought there might be a Kolber needing a prop. It's a four blade Powerfin with two blades. One blade has a repair in the outboard three inches where my wire frame bifocals went through the prop. The repair is CA mixed with cotton flox. Flew it about 6 hours total, it had one when the glasses flew off my neck, and replaced it. The other was replaced when some crush damage was found on one side of the blade shank. I was told this is normal for a Powerfin and the shanks of all the blades that came out of the hub showed similar damage during their ten year life.The blades are "F" type, 68" diameter. I ran it on an HKS on my my trike but I tried it on the Mk III with a 582 as a two blade and couldn't really tell much difference from the Warp Drive that it normally runs.
$200 + shipping
Rick Girard
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
232.24 KB |
3494 Time(s) |
229.46 KB |
3494 Time(s) |
258.04 KB |
3494 Time(s) |
253.7 KB |
3494 Time(s) |
Jerry-TS-MkII
Posted: Thu Sep 07, 2017 3:01 pm Post subject: Re: Powerfin prop for sale |
Did you see my PM? I'll try sending a email. THX!
