		dansbird
				 Posted: Mon Sep 04, 2017 5:09 pm    Post subject: Advise on radio and headset |
				I would like to get some input and advise on an inexpensive hand held radio and a headset as well. I looked on Ebay but there were way to many choices to pick from and I have no experience with radios at all.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Sep 04, 2017 5:50 pm    Post subject: Advise on radio and headset |
				I've flown all over CONUS, Canada, and Alaska, with an ICOM IC-A6 handheld.
 Sporty's has them for 239.00 dollars.  They come with a charger, headset adapter, and some other stuff.
 I fly with a DRE-6000 ANR headset, the cheapest of the ANRs, but they get the job done.
 http://www.sportys.com/pilotshop/icom-ic-a6-com-transceiver.html?utm_source=google_shopping&m=simple&utm_medium=cpc&utm_campaign=Radios+%26+Scanners&creative=76141183015954&device=c&matchtype=e
 MKIII
 Rock House, Burns Junction, Oregon
 ---- dansbird <hemidann(at)yahoo.com> wrote:
  http://forums.matronics.com/viewtopic.php?p=472493#472493
  _________________ John Hauck
Titus, Alabama |
		neilsenrm(at)gmail.com Guest
				 Posted: Tue Sep 05, 2017 8:29 am    Post subject: Advise on radio and headset |
				I have one Sigtronics headset that I have added a headsets inc. noise canceling kit to and another off brand headset that I use for passengers. Nether headset does the job. I have tried all kinds of foam ear plugs, ear buds, etc. under these and nothing worked very. A few years ago I purchased a set of Bose QC 20 ear buds that I wear under my heads sets and they are wonderful. I plug the Bose ear buds into my intercom via a adapter instead of my headsets. I use the headset microphone. I can fly for hours and my ears aren't ringing from the flight noise. I normally fly with both noise canceling systems turned on. I will fly without the Sigtronics noise canceling kit operating but never without the Bose canceling.
 I use the Bose ear buds for lots of other things also. When I was stuck on a long commercial flight next to a screaming child, I just sat there smiling.
 Rick Neilsen
 Redrive VW Powered MKIIIC
 On Mon, Sep 4, 2017 at 9:49 PM,  <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
  	  | Quote: | 	 		  --> Kolb-List message posted by: <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
  MKIII
  ---- dansbird <hemidann(at)yahoo.com (hemidann(at)yahoo.com)> wrote:
  > --> Kolb-List message posted by: "dansbird" <hemidann(at)yahoo.com (hemidann(at)yahoo.com)>
  WIKI -
				 Posted: Tue Sep 05, 2017 9:30 am    Post subject: Advise on radio and headset |
				i also have sigtronics headsets,,,,  the microphone were so sensitive they picked up a lot of background noise.....   I called the manufacturer and they told me how to decrease the Mike gain    it made a ton of difference...    They came at 100 percent,   I turned them all the way down...   With my hearing the way it is now,   I may need to turn it up 5 percent then see the difference.
 On Sep 5, 2017 10:32 AM, "Rick Neilsen" <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote: 	  | Quote: | 	 		  I have one Sigtronics headset that I have added a headsets inc. noise canceling kit to and another off brand headset that I use for passengers. Nether headset does the job. I have tried all kinds of foam ear plugs, ear buds, etc. under these and nothing worked very. A few years ago I purchased a set of Bose QC 20 ear buds that I wear under my heads sets and they are wonderful. I plug the Bose ear buds into my intercom via a adapter instead of my headsets. I use the headset microphone. I can fly for hours and my ears aren't ringing from the flight noise. I normally fly with both noise canceling systems turned on. I will fly without the Sigtronics noise canceling kit operating but never without the Bose canceling.
 Rick Neilsen
  MKIII
  WIKI -
		Mcabbage
				 Posted: Fri Sep 22, 2017 11:11 am    Post subject: Re: Advise on radio and headset |
				Hi John
 Do you use anything other than the stock antenna that came with your Icom?
 Thx Mike
  _________________ 2007  Firestar 2 503  N203SD
Moster 185 Flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike & Northwing Stratus XP |
				 Posted: Fri Sep 22, 2017 11:53 am    Post subject: Advise on radio and headset |
				I use a 21" ELT antenna, may be a 24".  Can't remember for sure.
 About 6' of coax cable trimmed for best SWR.
 The ICOM A6 is also very effective using the rubber ducky antenna.  I carry it in the aircraft in case I would have to use the radio outside the aircraft.
 I have had good luck with ICOM handheld radios.
 Rock House, Oregon
 ---- Mcabbage <Mc(at)americanbuilding.com> wrote:
  Hi John
  Thx Mike
  http://forums.matronics.com/viewtopic.php?p=473070#473070
Titus, Alabama |
		Mcabbage
				 Posted: Fri Sep 22, 2017 12:30 pm    Post subject: Re: Advise on radio and headset |
				Thank you John.
		lcottrell
				 Posted: Fri Sep 22, 2017 1:08 pm    Post subject: Advise on radio and headset |
				I believe the correct length for aircraft is 23.5 inches.
 Larry
 On Fri, Sep 22, 2017 at 1:52 PM,  <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
  Rock House, Oregon
  ---- Mcabbage <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)> wrote:
  > --> Kolb-List message posted by: "Mcabbage" <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)>
  > Hi John
  > Thx Mike
  WIKI -
		Mcabbage
				 Posted: Fri Sep 22, 2017 1:58 pm    Post subject: Re: Advise on radio and headset |
				Thank you Larry.
 Is it best to keep the antenna as far away from the engine as possible? I think I remember reading that somewhere.
 Does it matter?
		lcottrell
				 Posted: Fri Sep 22, 2017 2:03 pm    Post subject: Advise on radio and headset |
				I think most of us put them on the bottom of the cage, using the frame work to enable us to put in a ground plane to secure it to.Larry
 On Fri, Sep 22, 2017 at 3:58 PM, Mcabbage <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)> wrote:
  	  | Quote: | 	 		  --> Kolb-List message posted by: "Mcabbage" <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)>
  Thank you Larry.
  Does it matter?
  http://forums.matronics.com/viewtopic.php?p=473082#473082
  WIKI -
		Mcabbage
				 Posted: Fri Sep 22, 2017 2:10 pm    Post subject: Re: Advise on radio and headset |
				Ok I remember seeing a post about that a while back.
 Will do a search.  There was one on my plane before I stripped it of everything to sandblast the frame. I also have pics I took too.
 Mike
		ceengland7(at)gmail.com Guest
				 Posted: Fri Sep 22, 2017 2:19 pm    Post subject: Advise on radio and headset |
				There's a good article describing how to calculate length in a recent issue of Kitplanes. There are several 'correction factors' that should be applied (that shorten the length) after doing the speed of light/wavelength thing. IIRC, final answer for middle of the a/c comm band was closer to 21"
 BTW, if you're not a subscriber, Kitplanes is a really good resource for DIY homebuilt owner/maintainers. The current editor is a former NASA mission controller/manager who's also built a couple of RV's, a bush plane, and a motor glider. Lots of really good techy how-to stuff in addition to the 'feature' pieces. I've been doing pretty much everything mechanical for over 50 years, and I still learn something from every issue.
 Charlie
 On Fri, Sep 22, 2017 at 4:10 PM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
 I believe the correct length for aircraft is 23.5 inches. That should give you the best swr match.
 Larry
  Rock House, Oregon
  > Hi John
  > Thx Mike
		Mcabbage
				 Posted: Fri Sep 22, 2017 2:33 pm    Post subject: Re: Advise on radio and headset |
				Thanks Charlie will check out he magazine too!
		Jerry-TS-MkII
				 Posted: Fri Sep 22, 2017 2:52 pm    Post subject: Re: Advise on radio and headset |
				The location of the antenna can affect the radiation pattern.  If using a whip antenna, think of a doughnut over the wire.. and the signal strength is highest were the doughnut is thickest.  Very little signal strength off the end of the antenna.. it's broadside that works. Since we fly horizontally, put the whip near vertical, and in a clear area.  A aluminum disk can be placed under the fabric, to help establish a ground plane if needed on fabric airplanes, or the SWR shows high.  Since most of your communications will be with a tower, or another nearby plane, range isn't typically a major factor.  If the signal is weak.. fly higher.  That will have a more profound effect than any other factor, if the install is working.
 As with any remote antenna, make sure to use low loss foam core coax.. without sharp kinks, and put a SWR meter between the radio and the cable to make sure you don't have excessive standing waves (more likely caused by a short, or a bad antenna, or connector install if done by a individual).
 ECM, DF, and avionics repairman in Vietnam, 2nd class FCC license state side, and 2 more years avoinics, 2 years general 2-way communication, installs and bench service to component level on all.  Jerry
				 Posted: Fri Sep 22, 2017 3:03 pm    Post subject: Advise on radio and headset |
				That sounds about right.
 Rock House, Oregon
 ---- Larry Cottrell <lcottrell1020(at)gmail.com> wrote:
  	  | Quote: | 	 		   I believe the correct length for aircraft is 23.5 inches.
  Larry
  > aircraft.
  > john h
  > mkIII
  > Rock House, Oregon
  > > Hi John
  > Icom?
  > > Thx Mike
  > > Read this topic online here:
  *The older I get, the less tolerant I am of those who are intolerant of
  others.*
  *If you forward this email, or any part of it, please remove my email
  address before sending.*
Titus, Alabama |
				 Posted: Fri Sep 22, 2017 3:06 pm    Post subject: Advise on radio and headset |
				Meant to answer this in my previous.
 My antenna is mounted under the nose cone on a 6 inch diameter aluminum sheet ground plane.  The stainless steel whip has a 45 degree bend in it.
 Rock House, Oregon
  Thank you Larry.
  Does it matter?
Titus, Alabama |
		Mcabbage
				 Posted: Fri Sep 22, 2017 4:49 pm    Post subject: Re: Advise on radio and headset |
				Thanks John that is what the previous owner had. I guess I was being lazy and thinking to use a hand held stand alone.
 That being said I want as good as reasonable communications as possible so its worth the time to re install.
 Appreciate your help!
 Mike
