		Olivier.hequet@neuf.fr
				 Posted: Thu Sep 07, 2017 7:53 am    Post subject: 170cm 67" propeller  on a trigear |
				Hello,
 currently I have a 62 "warpdrive propeller on a trigear and I will change to an e-props. The distance between my current propeller and the ground is currently 30.5cm (12"). it is advisable to put a propeller of 170cm in diameter (67 "), in this case, there should be 24cm (9.4") between the ground and the propeller. do you think this calculation is correct or is it better to take a diameter 165cm (65 ")?
 Olivier
		JohnFrance
  Joined: 17 Sep 2014 Posts: 83 Location: Grenoble France
				 Posted: Fri Sep 08, 2017 1:21 am    Post subject: Re: 170cm 67" propeller  on a trigear |
				Hi Olivier,
 I have an Eprops Durandel 80S which is 1.6 m diameter on my mono-wheel using a 912 UL. That is already slightly bigger than the Warp drive 62". I did consider a bigger prop but was advised against it.
 I assume you have a 912ULS on a tri gear so you would require the Durandel 100 S.
 The propeller should not be able to contact the ground with the front tyre flat and the leg fully compressed you will need to find the relevant FAR's
 Do you need any information for the DGAC acceptance paperwork as I can supply a template?
  _________________ Europa mono Nr 192 |
				 Posted: Fri Sep 08, 2017 3:14 am    Post subject: Re: 170cm 67" propeller  on a trigear |
				Hello John
 If you could provide me with the DGAC documents, I would be delighted.
 Olivier olivier.hequet (at)neuf.fr
		Nigel Graham
  Joined: 23 Mar 2017 Posts: 36 Location: Winchester - UK
				 Posted: Fri Sep 08, 2017 7:37 am    Post subject: Re: 170cm 67" propeller  on a trigear |
				Not sure which standard your aircraft needs to comply with, but CS-VLA contains some "common sense" advice on propeller clearance.
 CS-VLA 925 Propeller clearance
  Unless smaller clearances are substantiated,
 propeller clearances with the aeroplane at
 maximum weight, with the most adverse centre
 of gravity, and with the propeller in the most
 adverse pitch position, may not be less than the
 following:
 (a) Ground clearance. There must be a
 clearance of at least 180 mm (for each aeroplane
 with nose wheel landing gear) or 230 mm (for
 each aeroplane with tail wheel landing gear)
 between each propeller and the ground with the
 landing gear statically deflected and in the level,
 normal take-off, or taxying attitude, whichever is
 most critical. In addition, for each aeroplane
 with conventional landing gear struts using fluid
 or mechanical means for absorbing landing
 shocks, there must be positive clearance between
 the propeller and the ground in the level take-off
 attitude with the critical tyre completely deflated
 and the corresponding landing gear strut
 bottomed. Positive clearance for aeroplanes
 using leaf spring struts is shown with a
 deflection corresponding to 1ยท5 g.
 The complete document can be found here:
 https://www.easa.europa.eu/system/files/dfu/CS-VLA%20%20Amdt%201%20combined.pdf
 Hope that is of some use to you.
 Nigel
				 Posted: Fri Sep 08, 2017 11:17 am    Post subject: Re: 170cm 67" propeller  on a trigear |
				John Nigel...thanks for all. I'm inform you as soon as possible.
 Bye
 Olivier
