Europa-List: Re: Battery
duanefamly(at)aol.com
PostPosted: Mon Sep 11, 2017 8:57 pm    Post subject: Europa-List: Re: Battery Reply with quote
From this past post, I believe the Butchers came up with the diode fix. Here is that post:
The ETX36C has been used successfully for years. The Rotax 914 charging system needs to be slightly modified to bring the charging voltage into the range the lithium battery likes (Jim and Heather brought that to my attention). A diode on the 'C' terminal of the Ducati regulator is adequate to fool the regulator into thinking the battery is at a slightly lower voltage than it actually is and so it will up its charge voltage, placing the battery into proper charging range. I think its 13.9 to 14.6 volts per the data sheet, if memory serves.
Sent from Windows Mail
Sent: ā€ˇMonday‎, ‎September‎ ‎11‎, ‎2017 ‎12‎:‎46‎ ‎PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
--> Europa-List message posted by: "italianjon" <jon.catilli(at)gmail.com>
Yes, I have. I've spent the evening trying to work out how it works on the standard Ducati Regulator of the 912.
Can anyone share the secret? My googling comes up blank.
Obviously, it's something to do with the voltage drop across the diode fooling the regulator, but I don't know enough about how voltage regulators work to understand it, or how exactly to wire it in. I guess it's not hard, but I don't want to $£%^ up a working system with a silly mistake Smile
http://forums.matronics.com/viewtopic.php?p=472804#472804
_-============================================================
_-=          - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Europa-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> http://www.matronics.com/contribution
