iLevil and Ipad
willydewey
PostPosted: Tue Sep 12, 2017 6:36 am    Post subject: iLevil and Ipad Reply with quote
I have purchased the latest SW iLevil and am looking for advice where to fit it.
I have played with it out of the aircraft and find that when rolling and turning it does not perform well and hangs up when the "aircraft" is level. I imagine the sensors need resetting but am not sure how this is done Leaving it swithed off for a day or so does not solve the problem.. I know one UK Europa has one fitted but I dont have contact with the builder/ owner..If I fit it atop of the cowling will the mass of the engine and other electronics affect the magnetometers? I am reluctant to fit it remotley as this would entail longish wire runs and messy plumbing for the static and pitot tubing
Any advice would be much appreciated
regards
Bill Dewey
Give a wise man knowledge and he will be yet wiser
clivesutton
PostPosted: Wed Sep 13, 2017 1:06 am    Post subject: Re: iLevil and Ipad Reply with quote
Hello Bill, i have one fitted, though the 2AW model. Contact me direct and we can talk/email in answer to your questions. Clive G-YETI
creightonious
PostPosted: Wed Sep 13, 2017 4:27 am    Post subject: iLevil and ipad Reply with quote
I have installed the iLevil on the lnstrument panel floor, carefully aligned and shimmed to level flight attitude. I use flyQ and the combination works very well for VFR. We do use 2 aging ipads for redundancy.
I'm reserving the space on the right center of the panel for the ultimate installation of a Grand Rapids or other unit in case I decide to get IFR current in the future.
We flew to Wyoming from Vermont, for the eclipse and found glare to be a non-issue. A small angle adjustment of the RAM mount always cured it. I recommend RAM mounts without reservation.
Creighton Smith. A009
On Sep 13, 2017, at 3:01 AM, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-09-12&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-09-12&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Tue 09/12/17: 11
Today's Message Index:
1. 01:04 AM - Re: Battery (Remi Guerner)
2. 01:48 AM - Re: Rebuilding my panel (willydewey)
3. 05:45 AM - Re: Re: Rebuilding my panel (Christoph Both)
4. 06:21 AM - Re: Rebuilding my panel (h&amp;jeuropa)
5. 07:02 AM - VENTILATION IN FLIGHT & POSITIVE CABIN PRESSURE (willydewey)
6. 07:35 AM - Re: VENTILATION IN FLIGHT & POSITIVE CABIN PRESSURE (Kevin Challis)
7. 07:36 AM - iLevil and Ipad (willydewey)
8. 07:43 AM - Re: Radio interference (willydewey)
9. 07:56 AM - Re: VENTILATION IN FLIGHT & POSITIVE CABIN PRESSURE (david park)
10. 09:56 AM - Re: Re: Radio interference (David Watts)
11. 05:53 PM - Re: VENTILATION IN FLIGHT & POSITIVE CABIN PRESSURE (Robert Borger)
________________________________ Message 1 _____________________________________
Time: 01:04:03 AM PST US
Subject: Re: Battery
Hello Jim,
> From what I read in the Rotax Install Manuals, all versions old and new, the Ducati
regulator is supposed to delivers 14 plus or minus .3 Volts. Mine consistently
regulates at 13,9 - 14 volts. I have been using an SB7800 lithium battery
for two years / 200 hours now and that works just fine.
Remi
http://forums.matronics.com/viewtopic.php?p=472818#472818
________________________________ Message 2 _____________________________________
Time: 01:48:38 AM PST US
Subject: Re: Rebuilding my panel
Anyone on this tack tried the iLevil in a EuropaXS ?
Where to mount it and what results obtained in flight.
I understand it transmits wirelessly to an Ipad or Andrid device.
Not over enamoured with these screens due to reflection issues
http://forums.matronics.com/viewtopic.php?p=472819#472819
________________________________ Message 3 _____________________________________
Time: 05:45:38 AM PST US
From: Christoph Both <christoph.both(at)acadiau.ca>
Subject: Re: Re: Rebuilding my panel
GRT since 5 years. Work great, affordable and good customer support.
Christoph Both
#223 Wolfville Nova Scotia, Canada
On 2017-09-11, 21:28, "owner-europa-list-server(at)matronics.com on behalf of Jeremy
Fisher" <owner-europa-list-server(at)matronics.com on behalf of jffisher(at)gmail.com>
wrote:
I can recommend GRT Avionics. Great support and less expensive.
Jerry Fisher
> On Sep 11, 2017, at 2:16 PM, Matt Dovey <mattdovey(at)hotmail.co.uk> wrote:
> Hi, I've not been very impressed with Dynon. My friend is on his 4th Skyview
screen. Returned one screen before the aircraft flew and another during test
flying. The other two since then.
> Had the quote through from Adams Aviation today for the Garmin G3X and G5.
> Sensors for a Rotax and all the other items for fitting 5,489 with out VAT.
Mad
> That's a far chunk of cash. I'll have a look for alternatives I think.
> http://forums.matronics.com/viewtopic.php?p=472799#472799
________________________________ Message 4 _____________________________________
Time: 06:21:34 AM PST US
When evaluating EFIS systems, be sure to look at the availability and cost of data
upgrades. You may find large differences.
Jim Butcher
http://forums.matronics.com/viewtopic.php?p=472826#472826
________________________________ Message 5 _____________________________________
Time: 07:02:30 AM PST US
Subject: VENTILATION IN FLIGHT & POSITIVE CABIN PRESSURE
I recently returned from a summer trip to Germany and Austria in G-IANI
wonderful trip but temperatures at 2000 ft rose in the cockpit to 44 deg C
and CO2 from the exhaust bothered me most of the time..
When on the ground the 914 was a problem to start probably by fuel being evaporated
in the carbs and consequential vapour lock
I have the Standard NACA vents (broken but open) but these didnt work at all well.
Ian gave me a Mecaplex vent which unfortunalty doesnt match the curve of the
screen and maybe it would if fitted foul the locking handle.
During the winter months I would like to redress the situation and would be grateful
for advice, in screen vents for example. Is it feasible to block or restrict
the entrance where the flap drive enters the fuselage? If this is possible
the CO2 problem might improve
Any help or tips much appreciated.
I do have the vapour return line installed back to the tank as required by the
LAA and was recently checked and a logbook entry made.
Once started from cold the 914 ran faultlessly even in those high temperatures
Both cylinder head and oil temperatures were within limits.
http://forums.matronics.com/viewtopic.php?p=472829#472829
________________________________ Message 6 _____________________________________
Time: 07:35:32 AM PST US
Subject: Re: VENTILATION IN FLIGHT & POSITIVE CABIN PRESSURE
Been through the same cabin ventilation issues tried negative pressure but carbon
monoxide in cockpit and a blast of air from my fuel selector location in the
tunnel.
I now have 3d printed deflectors on inside of air vents to direct air to blow over
body/face and an extra air vent on top of the cockpit also 3d printed with
a closable moveable vent inside to direct the air where required. It works well
but did take me 7 versions to get right.
Tested in SW France this summer.
Kevin Challis
G ODJG
well. Ian gave me a Mecaplex vent which unfortunalty doesnt match the curve of
the screen and maybe it would if fitted foul the locking handle.
________________________________ Message 7 _____________________________________
Time: 07:36:26 AM PST US
Subject: iLevil and Ipad
regards
Bill Dewey
http://forums.matronics.com/viewtopic.php?p=472832#472832
________________________________ Message 8 _____________________________________
Time: 07:43:16 AM PST US
Subject: Re: Radio interference
Hi Mike
I had a similar problem with my Europa and traced it down to my cheap Iphone/pad
charger.. I think the Guardian (not cheap) may be one way to go. Otherwise its
a suck it and see situation with liberal use of chokes and capacitors in circuits
Hope you can sort it
Bill Dewey
http://forums.matronics.com/viewtopic.php?p=472834#472834
________________________________ Message 9 _____________________________________
Time: 07:56:02 AM PST US
Simple and very effective available from ac spruce.
Dave Park G-LDVO
carbon monoxide in cockpit and a blast of air from my fuel selector locatio
n in the tunnel.
low over body/face and an extra air vent on top of the cockpit also 3d print
ed with a closable moveable vent inside to direct the air where required. It
works well but did take me 7 versions to get right.
> Kevin Challis
> G ODJG
vaporated in the carbs and consequential vapour lock
ll well. Ian gave me a Mecaplex vent which unfortunalty doesnt match the cur
ve of the screen and maybe it would if fitted foul the locking handle.
e grateful for advice, in screen vents for example. Is it feasible to block o
r restrict the entrance where the flap drive enters the fuselage? If this is
possible the CO2 problem might improve
y the LAA and was recently checked and a logbook entry made.
tures Both cylinder head and oil temperatures were within limits.
________________________________ Message 10 ____________________________________
Time: 09:56:03 AM PST US
Subject: Re: Re: Radio interference
Hi all
There have been several messages about radio interference from cheap USB chargers
and I keep meaning to put a message out about it as I have spent quite a bit
of time sorting this out.
What I have found is that there are car cigarette type chargers win USB outlets
that use a completely different electronic technology which they call Smart Charging
(not smart phone charging).
A good example of these is by a manufacturer called 1byOne and they market a triple
output charger with each outlet supplying up to 2.4 Amps. They are available
from Amazon for around 6. There are others available.
I and my friend have been using them for quite a while and there is no interference
at all no matter how close they are to the radio.
Dave Watts,
G-BXDY Classic Mono
> On 12 Sep 2017, at 15:43, willydewey <willydewey(at)gmail.com> wrote:
> Hi Mike
its a suck it and see situation with liberal use of chokes and capacitors in
circuits
> Bill Dewey
________________________________ Message 11 ____________________________________
Time: 05:53:58 PM PST US
Will,
I=99d have to recommend the Ultimate Ventilator available through
Aircraft Spruce. ( http://www.europaowners.org/main.php?g2_itemId=63921
http://www.aircraftspruce.com/catalog/appages/ultimatevent.php?clickkey=
29703 ) I have them installed on my Europa and they do an excellent job
of getting air into the cockpit. They aren=99t cheap, but I guess
this is a case of getting what you pay for.
Just my 2=C2=A2, YMMV.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com <mailto:rlborger(at)mac.com>
C
evaporated in the carbs and consequential vapour lock
all well. Ian gave me a Mecaplex vent which unfortunalty doesnt match
the curve of the screen and maybe it would if fitted foul the locking
handle.
be grateful for advice, in screen vents for example. Is it feasible to
block or restrict the entrance where the flap drive enters the fuselage?
If this is possible the CO2 problem might improve
by the LAA and was recently checked and a logbook entry made.
temperatures Both cylinder head and oil temperatures were within
limits.
Creighton Smith
A 036
