Twinstar Mk3 Classic MAUW
normros
PostPosted: Sat Sep 16, 2017 1:35 am    Post subject: Twinstar Mk3 Classic MAUW Reply with quote
Hi All, I've recently bought a Mk3 Classic, but I'm confused over the max weight. I'm in the UK so it's classified as a "microlight". According to the CAA (Civil Aviation Authority) MAUW is 390Kg (860lbs), the LAA (Light Aircraft Association) who administer the type, its 405Kg (892lbs), and I've seen it on other Kolb sites as 453Kg (1000lbs).
The engine is a 582 blue top.
Is there a "standard" MAUW for the aircraft on your side of the pond?, or do I "play safe" and use 390Kg.?
Thanks.
PostPosted: Sat Sep 16, 2017 8:34 am    Post subject: Twinstar Mk3 Classic MAUW Reply with quote
As the manufacturer of my Kolb MKIII I placarded my Kolb for 1,200 lbs max gross weight.
I have flown my MKIII at that take off weight many times in many different wind and weather conditions over the past 25 years and 3,400.0+ hours. I feel comfortable with the limits I imposed on my aircraft and feel it has been thoroughly tested over the years and hours since the first flight.
I believe Kolb Aircraft recommended 1,000.0 lbs max gross weight for the MKIII. I am not sure as I have never seen that figure on an official document.
During construction of my MKIII mods were made to increase strength and durability of the aircraft.
Although I placarded my MKIII at 1,200.0 lbs, I don't recommend anyone else doing that.
Rock House, Oregon
Thanks.
http://forums.matronics.com/viewtopic.php?p=472918#472918
normros
PostPosted: Mon Sep 18, 2017 8:56 am    Post subject: Re: Twinstar Mk3 Classic MAUW Reply with quote
Thanks John, I'm waiting to hear back from our LAA, but it looks like you guys can operate at a greater MAUW than we're allowed to.
Ross
normros
PostPosted: Fri Sep 22, 2017 4:00 am    Post subject: Re: Twinstar Mk3 Classic MAUW Reply with quote
Official MAUW is 390Kg (860lbs) in the U.K.
Richard Pike
PostPosted: Fri Sep 22, 2017 5:07 am    Post subject: Re: Twinstar Mk3 Classic MAUW Reply with quote
Gracious: With full fuel, I'd barely be able to take my granddaughter.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
