lcottrell
Joined: 29 May 2006 Posts: 1490 Location: Jordan Valley, Or
Posted: Fri Sep 22, 2017 1:11 pm Post subject: Fwd: Re: Advise on radio and headset |
I believe the correct length for aircraft is 23.5 inches. That should give you the best swr match.
Larry
On Fri, Sep 22, 2017 at 1:52 PM, <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
Quote: | --> Kolb-List message posted by: <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
I use a 21" ELT antenna, may be a 24". Can't remember for sure.
About 6' of coax cable trimmed for best SWR.
The ICOM A6 is also very effective using the rubber ducky antenna. I carry it in the aircraft in case I would have to use the radio outside the aircraft.
I have had good luck with ICOM handheld radios.
Rock House, Oregon
---- Mcabbage <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)> wrote:
> --> Kolb-List message posted by: "Mcabbage" <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)>
> Hi John
> Do you use anything other than the stock antenna that came with your Icom?
> Thx Mike
> 2007 Firestar 2 503 N203SD
> Moster 185 Flattop PPG/Sky K2 Paraglider
> Trike Buggy Soaring Trike & Northwing Stratus XP
> http://forums.matronics.com/viewtopic.php?p=473070#473070
WIKI -
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
