[Non-DoD Source] Re: YAK 52 - Procedure for emergency gear
wlannon(at)shaw.ca
PostPosted: Tue Sep 26, 2017 9:03 am    Post subject: [Non-DoD Source] Re: YAK 52 - Procedure for emergency gear Reply with quote
Hi Mark;
Agreed, it is a complicated question. Am I correct in assuming the shuttle
valves you refer to are the "Emergency" valves? They are indeed a shuttle
type valve but are designed to default (via spring pressure) to the "normal"
position in the event of a zero pressure situation as you describe in your
example.
In that example it would seem that, if the handle was left in the up
position, an immediate unsafe gear situation would result. Retraction may
be prevented by trapped air in the down side but down locks would be
disengaged. No such problem with the selector in the down position.
All the best;
Walt
