No SNOT
Goto page 1, 2  Next
Dawg
PostPosted: Fri Oct 13, 2017 7:35 pm    Post subject: No SNOT Reply with quote
No air or discharge from SNOT valve. New air compressor, new pop-off valve, cleaned entire valve, snot valve seals properly, new check valve at fill point, sprayed so much soapy water that I was afraid to turn on electricity. No leaks found all the way to the gauges. Blew air from compressor in to airplane: snot valve is clean and tight, bottle pressure increased.
Not much else to change. Any thoughts?
Dawg
Ernie
PostPosted: Sat Oct 14, 2017 3:32 am    Post subject: No SNOT Reply with quote
Plugged line prior to snot valve?
On Fri, Oct 13, 2017 at 11:38 PM William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
--> Yak-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
dsavarese0812(at)bellsout
PostPosted: Sat Oct 14, 2017 3:48 am    Post subject: No SNOT Reply with quote
Bill,
You said the bottle pressure increases. In your judgement, is it taking longer to fill the air bottle or about the same amount of time?
Did you remove the snot bottle and flush out all 3 orifices? ie: Input side; Output side AND the drain? You can immerse the snot bottle in avgas, shake it around inside the snot bottle, then with your fingers, plug up two openings and let it drain out the 3rd opening. Repeat the process for all 3 openings until everything that flushes out is avgas-clear.
Dennis
To: Yaklist <yak-list(at)matronics.com>
Sent: Friday, October 13, 2017 11:36 PM
Subject: No SNOT
s.matronics.com/" target="_blank">http://forums.matronics.com
_-= --> http://www.matronics.com/contribution
draftsjust417(at)gmail.co
PostPosted: Sat Oct 14, 2017 5:31 am    Post subject: No SNOT Reply with quote
Sounds like everything that can and should be checked/replaced/cleaned has been, possibly (?) barring extensive port cleaning Dennis describes...I'm wondering... is there a minimum system pressure required in the main tank & lines before the snot-pot will give its typical & very audible behavior?
Justin
On Sat, Oct 14, 2017 at 7:47 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Bill,
Dennis
From: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
To: Yaklist <yak-list(at)matronics.com (yak-list(at)matronics.com)>
PostPosted: Sat Oct 14, 2017 5:39 am    Post subject: No SNOT Reply with quote
No.  The snot bottle is an air-oil separator anddoes its jobfrom the
beginning of the first burst of air pressure from the compressor.
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
describes...
audible behavior?
Justin
<dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
Bill,
Dennis
*From:* William Geipel <l129bs(at)gmail.com <mailto:l129bs(at)gmail.com>>
*To:* Yaklist <yak-list(at)matronics.com
<mailto:yak-list(at)matronics.com>>
*Sent:* Friday, October 13, 2017 11:36 PM
<http://www.matronics.com/Navigator?Yak-List>
*s.matronics.com/ <http://s.matronics.com/>"
<http://forums.matronics.com>
*http://www.matronics.com/contribution
Dawg
PostPosted: Sat Oct 14, 2017 6:07 am    Post subject: No SNOT Reply with quote
Nope. Blew air from air compressor to the snot valve. Valve open blew air thru it. closed, no leak.
On Oct 14, 2017, at 05:31, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
--> Yak-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> No air or discharge from SNOT valve. New air compressor, new pop-off valve, cleaned entire valve, snot valve seals properly, new check valve at fill point, sprayed so much soapy water that I was afraid to turn on electricity. No leaks found all the way to the gauges. Blew air from compressor in to airplane: snot valve is clean and tight, bottle pressure increased. Not much else to change. Any thoughts? =========== List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ===========
Dawg
Dawg
PostPosted: Sat Oct 14, 2017 6:09 am    Post subject: No SNOT Reply with quote
A little faster now but only gets to 3.5.
On Oct 14, 2017, at 05:47, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Bill,
Dennis
From: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> To: Yaklist <yak-list(at)matronics.com (yak-list(at)matronics.com)> Sent: Friday, October 13, 2017 11:36 PM Subject: No SNOT
Dawg
dougsappllc(at)gmail.com
PostPosted: Sat Oct 14, 2017 6:22 am    Post subject: No SNOT Reply with quote
I assume that you are making air?  If yes how long does it take to reach pop off (at) 45 ATMS?When you compressor installed did you use new crush washers?
Have you checked the line and line fittings from compressor to snot valve?
I have a compressor test set if needed.
Doug
On Fri, Oct 13, 2017 at 8:33 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
WIKI -
pa3arw(at)ziggo.nl
PostPosted: Sat Oct 14, 2017 6:45 am    Post subject: No SNOT Reply with quote
Dennis,
I don't wanna be a smart ass but I think you mean air-water separator(?)
rather then air-oil separator.
After all in our air system in the Yak and I assume in the CJ as well you
wanna have some oil in the air...better for the actuators...
I think, despite the swap of all items already, there is only one thing left
again to replace...the air compressor.
In the beginning of my Yak career I have had 3 compressors that were not
doing what they were supposed to do i.e. deliver 50 bars of air. Now since
the last 12 years I've had no problem whatsoever....touch wood!
Hans O.
PH-YAK
Op 14-10-17 15:38, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> schreef:
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> describes...
> audible behavior?
> Justin
> Bill,
> Dennis
PostPosted: Sat Oct 14, 2017 7:09 am    Post subject: No SNOT Reply with quote
Oops. You are correct. My bad.
On Oct 14, 2017, at 10:43 AM, Hans Oortman <pa3arw(at)ziggo.nl> wrote:
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>> Bill,
>> Dennis
Dawg
PostPosted: Sat Oct 14, 2017 10:28 am    Post subject: No SNOT Reply with quote
checking snot valve today. We have not flown it yet. On the ground takes about 12 minutes to get 3.5. And that is from about 2. After that, nothing from snot valve.
On Oct 14, 2017, at 08:21, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
I assume that you are making air? If yes how long does it take to reach pop off (at) 45 ATMS?When you compressor installed did you use new crush washers?Have you checked the line and line fittings from compressor to snot valve?
Doug
--> Yak-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> No air or discharge from SNOT valve. New air compressor, new pop-off valve, cleaned entire valve, snot valve seals properly, new check valve at fill point, sprayed so much soapy water that I was afraid to turn on electricity. No leaks found all the way to the gauges. Blew air from compressor in to airplane: snot valve is clean and tight, bottle pressure increased. Not much else to change. Any thoughts? ==================================== List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List ==================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com ==================================== WIKI - errer" target="_blank">http://wiki.matronics.com ==================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ====================================
Dawg
Dawg
We replaced the compressor. This is a new rebuild.
On Oct 14, 2017, at 08:43, Hans Oortman <pa3arw(at)ziggo.nl> wrote:
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>> Bill,
>> Dennis
Dawg
PostPosted: Sat Oct 14, 2017 11:24 am    Post subject: No SNOT Reply with quote
Rebuilt compressor may very well be the problem. Over the years I've seen several so-called "rebuilt" compressors fail in more ways than one.
Dennis
Sent: Saturday, October 14, 2017 2:30 PM
Subject: Re: No SNOT
On Oct 14, 2017, at 08:43, Hans Oortman <pa3arw(at)ziggo.nl (pa3arw(at)ziggo.nl)> wrote:
--> Yak-List message posted by: Hans Oortman <pa3arw(at)ziggo.nl (pa3arw(at)ziggo.nl)>
Dennis,
the last 12 years I've had no problem whatsoever...touch wood!
Hans O.
PH-YAK
Op 14-10-17 15:38, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> schreef:
> --> Yak-List message posted by: "A. Dennis Savarese"
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>> <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net) <mailto:dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>> wrote:
>> Bill,
>>   Dennis
>> *From:* William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com) <mailto:l129bs(at)gmail.com (l129bs(at)gmail.com)>>
>> *To:* Yaklist <yak-list(at)matronics.com (yak-list(at)matronics.com)
>> <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>>
http://www.matronics.com/Navigato - MATRONICS WEB FORUMS -
http://forums.msp; - NEW MATRONICS LIST WIKI -
http://www.matronics.com/cont========================
glipaz
PostPosted: Sat Oct 14, 2017 4:48 pm    Post subject: Re: No SNOT Reply with quote
Likely your snot valve is leaking. It might be leaking from the needle valve or the base of the valve (bottom part of the snot bottle) is not tight. I had same issue. Tightened bottom part and it built pressure again.
markdavis(at)wbsnet.org
PostPosted: Mon Oct 16, 2017 8:57 am    Post subject: No SNOT Reply with quote
Update on the notso snotty snot valve.  We removed it yesterday and it was completely obstructed with coagulated snot/debris.  30 minutes of flushing with avgas still had it letting small and large chunks go.  We switched to hot tap water with Dawn dishwashing detergent and that seemed to let bigger chunks go faster.  We vibrated it with the rough spot on a bench grinder as is sped up and slowed down, beat on it with the plastic handle of a screwdriver and blew it out after every flush/cleaning attempt.  It took two hours and probably 40 cleaning cycles before it looked like we were getting to the end of the junk.  The final flushes with avgas dumped into a coffee filter looked pretty good.  It now works properly.  If we'd had an ultrasonic cleaner it probably would have been the best method to get it all soaked/vibrated loose.
The rebuilt compressor works fine.  The rubber tip on the piston in the pop off valve was bad and limiting the pressure build up.
Mark Davis
N44YK
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Saturday, October 14, 2017 1:23 PM
To: yak-list(at)matronics.com
Dennis
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>>  Bill,
>>  Dennis
PostPosted: Mon Oct 16, 2017 9:12 am    Post subject: No SNOT Reply with quote
Many people completely ignore flushing the snot bottle every couple of years and the result is exactly what you've experienced Mark. Glad you got it fixed.
Dennis
Sent: Monday, October 16, 2017 12:58 PM
Subject: RE: No SNOT
Mark Davis
N44YK
Dennis
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>>  Bill,
>> Dennis
hkgibby(at)yahoo.com
PostPosted: Mon Oct 16, 2017 9:52 am    Post subject: No SNOT Reply with quote
Regarding the corroded snot bottle "innards"; recommend replacing both firewall and belly with a modern SS swagelok ball valve. Won't ever rust so two less future headaches. Awesome mod!! I have learned the hard way that with our pneumatic systems any chance to change to stainless steel components/springs, along with regular preventative maintenance WILL make for a healthier system. My 2 cents.
Hoot
On Oct 16, 2017, at 1:10 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
From: Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)>
Mark Davis
N44YK
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of A. Dennis Savarese
Dennis
Subject: Re: Yak-List: No SNOT
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>> Bill,
>> Dennis
richard.goode(at)russiana
PostPosted: Mon Oct 16, 2017 10:06 am    Post subject: No SNOT Reply with quote
Ultrasonic cleaning is really the only way to go for this kind of long-term congealed stuff. This is particularly true of oil coolers – we have many customers complaining of hot oil, and the simple problem is that they are using 30 year old oil coolers which people have said that they have "cleaned", simply by flushing them with fuel and other solvents. The problem is that they have hardened oil insulating the cooler, and the only way to get rid of this is with ultrasonic cleaning.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel:  +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Mark Davis
Sent: 16 October 2017 17:56
Mark Davis
N44YK
Dennis
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>>  Bill,
>>  Dennis
believed to be clean.
PostPosted: Mon Oct 16, 2017 10:12 am    Post subject: No SNOT Reply with quote
Excellent point Richard.
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *Mark Davis
*Sent:* 16 October 2017 17:56
*To:* yak-list(at)matronics.com
*Subject:* RE: No SNOT
Mark Davis
N44YK
<mailto:owner-yak-list-server(at)matronics.com>
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *A. Dennis
Savarese
*Sent:* Saturday, October 14, 2017 1:23 PM
*To:* yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
*Subject:* Re: No SNOT
Dennis
*From:*William Geipel <l129bs(at)gmail.com <mailto:l129bs(at)gmail.com>>
*To:* Yaklist <yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>>
*Sent:* Saturday, October 14, 2017 2:30 PM
> On Oct 14, 2017, at 08:43, Hans Oortman <pa3arw(at)ziggo.nl <mailto:pa3arw(at)ziggo.nl>> wrote:
> Dennis,
> Regards,
> Hans O.
> PH-YAK
>> A. Dennis Savarese
>> www.yak-52.com <http://www.yak-52.com>
>> Skype - Yakguy1
>>> describes...
>>> audible behavior?
>>> Justin
<mailto:dsavarese0812(at)bellsouth.net>>> wrote:
>>>    Bill,
>>>    Dennis
<mailto:l129bs(at)gmail.com <mailto:l129bs(at)gmail.com>>>
>>>    <mailto:yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>>>
>>>    target="_blank">http://forums.matronics.com <http://forums.matronics.com/>
>>>    <http://forums.matronics.com <http://forums.matronics.com/>>
_
<http://forums.matronics.com/>_
_
_
_
dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
PostPosted: Mon Oct 16, 2017 10:19 am    Post subject: No SNOT Reply with quote
Dennis,
     Not my YAK,  just throwing in a hand to get it up and running.  Bill's in Korea (South) torturing 777 pilots for Boeing.   I intend to flush mine now this winter, even though it "blows" lots of snot.  Any reduced capacity from built up crud likely decreases its efficiency in separating the water.   I think I'll try the ultrasonic cleaning method as well since I likely won't be in a hurry to get it back up and running.   Lots of time to spare when my hangar has deep snow drifts in front of it......
Mark
Sent: Monday, October 16, 2017 11:11 AM
Dennis
Mark Davis
N44YK
Dennis
Dennis,
Hans O.
PH-YAK
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> describes...
>> audible behavior?
>> Justin
>>  Bill,
>>  Dennis
Goto page 1, 2  Next
Page 1 of 2
