stephenbehn(at)bigpond.co Guest
Posted: Wed Sep 27, 2017 2:43 am Post subject: Canopy Protective Coating |
Hello Group,
Has anyone had success with removing the protective coating on the canopy bubble other than with your thumb nail. Its easy where the coating is thick but on the inside it is really thin and almost impossible to get off.
Cheers
Steve Behn
Lightning 69
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
n5pb(at)AOL.COM Guest
Posted: Wed Sep 27, 2017 8:36 am Post subject: Canopy Protective Coating |
Steve, I scrapped mine at the factory. they had a scraper which I believe was made out of Plexiglas and worked perfectly. Check with Nick.
He might be able to give you more info, since this was several years ago.
Bear
Posted: Sun Oct 01, 2017 8:51 pm Post subject: Canopy Protective Coating |
Bear thanks for the suggestion I made up a plexi glass scraper out of a cut off piece of the canopy, did get a few light scratches using it but was able to polish them out with metal polish. It was a really slow and tedious job. I am sure it was so because the film had been on the canopy for a long time and had hardened on there. If anyone has an older kit with the canopy still protected I would remove it and reapply a new thick coat Aircraft Spruce seem to have it.
Steve
Sent: Thursday, September 28, 2017 2:34 AM
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com) ; nick(at)flylightning.net (nick(at)flylightning.net)
Subject: Re: Canopy Protective Coating
Bear
-----Original Message-----
To: lightning-list <lightning-list(at)matronics.com>
Sent: Wed, Sep 27, 2017 7:35 am
Subject: Canopy Protective Coating
Hello Group,
Cheers
Steve Behn
Lightning 69
Posted: Mon Oct 02, 2017 5:31 am Post subject: Canopy Protective Coating |
Steve,
glad you were able to get the film off. As I recall, it did take me a little while too to scrape the film off the entire canopy. I do think the canopy was relatively new and the film hadn't "hardened", but it was tedious.
Continued luck with your build...
Bear
N82PB
