Rotax 503 GHT probe Question
RoHam
PostPosted: Mon Oct 30, 2017 11:16 am    Post subject: Rotax 503 GHT probe Question Reply with quote
Looking over my motor and found I had oil leaking around the plug with the cht probe on it. Should the original plug gasket be with these probes or discarded? Anyone ever use a different location for probes, such as a head bolt? wondering how to remedy Question
woody
PostPosted: Mon Oct 30, 2017 5:38 pm    Post subject: Re: Rotax 503 GHT probe Question Reply with quote
My 503 has similar leakage on the rear cyl. as well. To my knowledge, it has done this since I brought it home, about 80 eng. hrs. ago. I get a film on the shroud below the head on the Carb. side. It wipes right off...........
Richard Pike
PostPosted: Mon Oct 30, 2017 6:20 pm    Post subject: Re: Rotax 503 GHT probe Question Reply with quote
Similar application, good ideas. http://inventions.aerocorsair.com/id77.htm
From the Challenger page: http://challengers101.com/CHT_Sensor.html
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
RoHam
PostPosted: Tue Oct 31, 2017 12:42 am    Post subject: Re: Rotax 503 GHT probe Question Reply with quote
I don't worry about the mess it makes, I don't like the fact it's leaking by the plug seat. Thanks for the links Richard I'll check them when I get home from work. ...Later
