tshort
Posted: Tue Nov 14, 2017 11:02 am Post subject: B&C Starter with Plane Power alternator - need bracket |
Anyone know if there is an off the shelf bracket that fits between the B&C lightweight starter and the 60A PP alternator?
I'm installing the B&C starter during the upgrade to the panel, and the original steel bracket is nowhere close to fitting.
Thanks in advance
bob88
Posted: Tue Nov 14, 2017 2:02 pm Post subject: Re: B&C Starter with Plane Power alternator - need brack |
I had the same problem. Neither of the links B&C provides will work. I ended up bending the Plane Power link (only slightly) and drilling a new 5/16 hole effectively shortening the link. I inserted the long bolt from behind with some wet torque seal on the end to mark the place to drill the new hole. Hope this helps.
