Intersection Fairings and Oil Cooler Valve
mhealydds
PostPosted: Fri Nov 17, 2017 5:36 pm    Post subject: Intersection Fairings and Oil Cooler Valve Reply with quote
Just finished my first condition inspection and want to do finish some items while plane open and though I might get some input....
1. I still have yet to install upper main leg intersection fairings - for attachment to fuse bottom do you all you use the self tapping screws as in plans, rivnuts, or another clever solution?
2. I am installing an oil cooler valve - how did you all attached to oil mount? (clamps, screws, etc?)
Matt
philperry9
PostPosted: Fri Nov 17, 2017 6:30 pm    Post subject: Intersection Fairings and Oil Cooler Valve Reply with quote
1) Self tapping screws. Will probably change to nut plates at some point if they strip out or begin working out with vibration.
2) Mine is mounted on top of the oil cooler plenum. Then the scat tube attached to it. The butterfly valve is secured with LP4-3’s.
It does need to be secured otherwise the push cable rotates the valve around instead of operating the valve.
Matt
http://forums.matronics.com/viewtopic.php?p=475187#475187
jesse(at)saintaviation.co
PostPosted: Sun Nov 19, 2017 12:05 pm    Post subject: Intersection Fairings and Oil Cooler Valve Reply with quote
See below.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
It varies. Pointy screws work fine.
2. I am installing an oil cooler valve - how did you all attached to oil mount? (clamps, screws, etc?)Pop rivets.
Matt
