Towbars and FBOs
digidocs
PostPosted: Sat Nov 25, 2017 6:45 pm    Post subject: Towbars and FBOs Reply with quote
Do FBO's usually have a towbar that will fit on an RV-10?  I thought I remember reading that the answer is usually not and have a hazy memory of a modification to enable standard towbars to fit.  What says the list?
I know a number of folks simply ask the FBO not to move the airplane, but at least with FBOs I've encountered that may be a bit much to ask.
David
maca2790
PostPosted: Sun Nov 26, 2017 12:25 am    Post subject: Towbars and FBOs Reply with quote
Hi Guys,
Being downunder I am not familiar with the Acronym FBO.
I know they must be the people that help marshal aircraft but can someone fill me in?
Cheers
John MacCallum
VH-DUU
RV 10 # 41016 Flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Carr
Sent: Sunday, 26 November 2017 1:43 PM
Subject: Towbars and FBOs
David
dan(at)syz.com
PostPosted: Sun Nov 26, 2017 2:58 am    Post subject: Towbars and FBOs Reply with quote
I've been to around 15-20 FBOs last year (US and Canada) and though I brought my tow bar with me the first few flights, I soon started leaving it at home, since all the FBOs that needed to move my plane had a way of doing so. Most have tow bars with interchangeable ends... I know that at one FBO, they commented that they had to change out the ends for what they used for some model of light jet (can't remember which one), but so far (knock on wood), they've all had a way of fitting.
I do have slightly enlarged access holes to the bolts on the nose gear.. I can't remember by how much, but they are a bit larger than called for on the plans. Maybe that helps.
I plan on modifying the tow bar bolts shortly to sit flush with the wheel fairings instead of recessed inside so that in case a tow bar slips off it doesn't destroy the fairing, so when that's done it should be even easier for generic tow bars to fit. But regardless, I haven't had any problem with Van's stock design (albeit with slightly enlarged access holes as I said).
Dan
David
Dan Charrois
President, Syzygy Research & Technology
Phone: 780-961-2213
rleffler
PostPosted: Sun Nov 26, 2017 4:56 am    Post subject: Towbars and FBOs Reply with quote
Fixed base operator, your assumption is correct.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of John MacCallum <john.maccallum(at)bigpond.com>
Sent: Sunday, November 26, 2017 3:24:12 AM
Subject: RE: Towbars and FBOs
Hi Guys,
Cheers
John MacCallum
VH-DUU
David
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Kelly McMullen
PostPosted: Sun Nov 26, 2017 6:35 am    Post subject: Towbars and FBOs Reply with quote
FBO=Fixed Base Operator. The company that provides fuel, parking, possibly maintenance at an airport. May also be associated with or run a flight school, rent aircraft, etc.
-sent from the I-droid implanted in my forearm
On Sun, Nov 26, 2017 at 1:24 AM, John MacCallum <john.maccallum(at)bigpond.com (john.maccallum(at)bigpond.com)> wrote:
Hi Guys,
Cheers
John MacCallum
VH-DUU
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David Carr
David
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
dmaib(at)mac.com
PostPosted: Sun Nov 26, 2017 7:09 am    Post subject: Towbars and FBOs Reply with quote
As others have noted, a business that provides fuel, hangars, tie-downs, perhaps maintenance, flight training, etc. I believe the origin of the term “Fixed Base Operator” goes back to the very early days of aviation in this country. “Barnstormers” flew around the country selling airplane rides, performing at county fairs, maybe providing a charter service, or whatever else they could do to make a $ and had no “fixed base” of operations. The term FBO differentiated the barnstormer from the operator that had a fixed place of business.
David Maib
N380DM
RV-10 #40559 (will go over 1000 hours next week!)
On Nov 26, 2017, at 3:24 AM, John MacCallum <john.maccallum(at)bigpond.com (john.maccallum(at)bigpond.com)> wrote:
Hi Guys,
Cheers
John MacCallum
VH-DUU
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David CarrSent: Sunday, 26 November 2017 1:43 PMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Towbars and FBOs
David
